roscoemi 245 #1 Posted December 15, 2012 I bought a 1967 Lawn Ranger for my son for Christmas and need some help hooking up the snow plow. I could find no numbers on the plow, but assume there is a bracket to bolt the pivot point to the frame. I'm thinking it should bolt up in the area under the motor where holes are located and the front deck swing arms mount. I'm going to look at the attachments forum to see what I can find, and contact Kelly to see if he has any ideas. If anyone has pics or one they are willing to part with please let me know, as I would really like the plow on when my son finds his special present from Santa. Russ Share this post Link to post Share on other sites
roscoemi 245 #2 Posted December 15, 2012 After searching, I believe the plow is part #6-3111 (supercedes bdr-385). The bracket part number is 4123 and the wear bar number is 5863. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #3 Posted December 15, 2012 Click the following link to view the information you seek: Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted December 15, 2012 You need a front Attach-A-Matic Share this post Link to post Share on other sites
roscoemi 245 #5 Posted December 15, 2012 Thanks guys, I really appreciate the info. the link has great pics and I can fab them to the print, but will not get them done in time for Christmas.Just another chance to work with Porkchop and teach him some fab skills. He will be excited to get his own 'Horse, but to work on it to get it plowing snow may send him into parts unknown! Thanks again guys! :thanks: Share this post Link to post Share on other sites
305 381 #6 Posted December 17, 2012 i had to make those brackets for my lawn ranger snow blade too, used that print and they work great, i used 5/16" instead of 1/4" because i had it Share this post Link to post Share on other sites
Lane Ranger 12,094 #7 Posted December 17, 2012 This is a photo of an attach a matic (a version later than the original two flat plates used) for the Lawn Ranger that will work for your plow: 1 Share this post Link to post Share on other sites
Fun Engineer 863 #8 Posted December 17, 2012 Russ Let me look in the shed and see what I have. I may have the newer style that is pictured above. If I do, its yours. I'll let you know after Christmas. Dave Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #9 Posted December 17, 2012 This is a photo of an attach a matic (a version later than the original two flat plates used) for the Lawn Ranger that will work for your plow: That is technically the MA-1 (8-5211) speed hitch - the predecessor to the Tach-A-Maticâ„¢, which preceeded the Attach-Maticâ„¢. It is also assembled backwards as pictured. I have never attempted to install the Lawn Ranger blade in the speed hitch. Is there enough clearance for the latch? Share this post Link to post Share on other sites
Kelly 1,038 #10 Posted December 17, 2012 Well I just this morning shipped him the solid side plates so he should be all set, but I do wonder if the speed hitch will work? Share this post Link to post Share on other sites
Lane Ranger 12,094 #11 Posted December 17, 2012 TT/Kelly and other Red Square members: The photo with the quick attach was when I first got my plow and Lawn Ranger about five years ago. I recall that the plow would lock on to the plates with the spring lock but I never used it to plow with. I bought two sets of original flat plates afterwards and that is what I have been using. I looked around this afternoon and I still have the later vervsion quick attach but I can not find the locking arm to go between the plates. So we I should probably put a BIG MAY WORK On tis one!! Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #12 Posted December 17, 2012 ...........I do wonder if the speed hitch will work? Negative - I just checked a latch from an 854 speed hitch against a Lawn Ranger blade and it doesn't fit. :confusion-shrug: Share this post Link to post Share on other sites
Lane Ranger 12,094 #13 Posted December 17, 2012 Thanks for checking and correcting me on this TT! Members need the correct information! Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #14 Posted December 17, 2012 :text-thankyoublue: Lane! I wasn't trying to stir things up. I know that the latches on the speed hitch (and later versions) burn up an extra 1/2"+ between the side plates. I thought the LR blade was a snug fit between the side plates, but wasn't home earlier to check it out. 1 Share this post Link to post Share on other sites
roscoemi 245 #15 Posted December 18, 2012 Thanks Kelly, was going to pm you to see if you got them shipped. Thanks also to the others who took the time to help me out! Some good info there. Do you suppose that a speed hitch could be modified or one fabbed to work with a 1/4" spacer on each side to make enough clearance? Is the pivot bar the same diameter to work in the speed hitch? Share this post Link to post Share on other sites
roscoemi 245 #16 Posted December 18, 2012 Thanks Dave. It's up and running, Porkchop will be wound for sound on Christmas morning! :text-merryxmas: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #17 Posted December 18, 2012 Do you suppose that a speed hitch could be modified or one fabbed to work with a 1/4" spacer on each side to make enough clearance? Is the pivot bar the same diameter to work in the speed hitch? You'd have to widen the latch assembly enough to clear the blade mount and shim the side plates away from the tractor frame to match. The mounting rod is 3/4" and will fit in the speed hitch slots. Share this post Link to post Share on other sites
roscoemi 245 #18 Posted December 18, 2012 Thanks TT. I think I may give it a shot once the holidays are over. Share this post Link to post Share on other sites
Fun Engineer 863 #19 Posted December 18, 2012 Thanks Dave. It's up and running, Porkchop will be wound for sound on Christmas morning! Glad Kelly could help you out. Sounds like my MA-1 (8-5211) speed hitch wouldn't have worked. Give Porkchop a big hug on Christmas morning. Make sure momma has the camera ready to capture the look on his face. Share this post Link to post Share on other sites
roscoemi 245 #20 Posted December 19, 2012 Already planned, she will be out there and ready. I'm gonna try to get one to modify or duplicate so it's wider to make the plow easier to take off for joy rides between storms. He will worry it to death if he doesn't get seat time. He has about wore out the hinges on the cab doors of mine "checkin to make sure everything is ready"! I hope that Ranger is good on gas or I"ll be broke in a week or two! Share this post Link to post Share on other sites
Kelly 1,038 #21 Posted December 19, 2012 I'm not sure the stubs of the shaft on the plow, will extend all the way through the latch and the hitch on the speed hitch, can you tell me how much shaft you have sticking out? and I can see if it might work. Share this post Link to post Share on other sites
roscoemi 245 #22 Posted December 19, 2012 I'll try to get some dims tommorrow but, we're lookin at a foot of snow starting in the afternoon so it might not happen. I guess there is about 3/4" on each side which can be modified. I would just like to make an easier/faster way to mount the plow as he will run the wheels off this tractor when he gets his little paws on it. If i can get a speed mount along with a regular set of brackets, I can figure something out and post the results. Share this post Link to post Share on other sites
skip150 7 #23 Posted March 2, 2013 U guys r GREAT HELL I might even attempt a speed hitch now Thanks again EVERYONE Share this post Link to post Share on other sites
roscoemi 245 #24 Posted March 2, 2013 BTW, P'Chop has run the wheels off the Ranger! If he doesn't get seat time he gets all kinds of upset! He is now the plow guy, and I better get over it! lol Share this post Link to post Share on other sites
