WHEEL HORSE BILL
Now getting mad my C-121 WON"T FIRE.
WHEEL HORSE BILL
I got a C-121 and redoing the hole thing over as a puller for my son who is 9.I'm using all the original wiring from it, put it back together and now won't fire why :banghead: ? Is there a way to test the solenoid.I checked everything. Retraced all my wiring.Can anyone help.Battery is good.I jumped the solenoid and it turns over fine :confusion-confused: but when i turn the key it win't do anything. :eusa-think:
TT
Safety switches? All there and working properly?
Is there power to the ignition switch?
Are both ammeter wires connected?
WHEEL HORSE BILL
How can I check the switches to see if they are good.
I followed the wiring diagram here on RS.
TT
Do you have a multimeter or a test light?
WHEEL HORSE BILL
I think I have a test light my brother left behind here at my place.
TT
Use the test light to see if there is power to the "B" terminal at the ignition switch first.
Did you 'jump' the solenoid across the two large posts or did you apply power to the small post?
WHEEL HORSE BILL
To the 2 big posts.the test light where do I put the clip to.I hate electrical.
TT
I sent you a PM. :handgestures-thumbup:
JackC
Make sure the breaker points are good and clean and set properly. Try cleaning them with emery cloth and see if that helps.
TT
It wasn't spark 'fire'...... it was electrically dead at the switch.
Unfortunately while we were conversing over the phone, we came to realize that a new test light doesn't mean a working test light. :eusa-whistle:
Rock farmer
I just instinctively test the test light across the battery terminals before I do anything else.
I must have wasted enough time with a bad test light sometime in my past!
Joe
