Stepney 2,354 #1 Posted December 7, 2012 Hello all, I was wondering something, (Again). I have a late model 42" Recycle deck, and am planning on rebuilding the spindles this winter. Would these bearings be the right ones? I couldn't find much information on the spindles. http://www.ebay.com/itm/6-Mower-Deck-Spindle-Bearings-for-Wheel-Horse-109966-/300571831155?pt=LH_DefaultDomain_0&hash=item45fb7a2b73 Or this? http://www.ebay.com/itm/6-spindle-bearings-wheelhorse-toro-snapper-109966-sealed-2-sides-/221156476392?pt=LH_DefaultDomain_0&hash=item337df405e8 Thanks, Spenser. Share this post Link to post Share on other sites
Don1977 605 #2 Posted December 7, 2012 There is no way to tell with out knowing what deck you have. Does your deck have metric spindles if so they should have a 5/8" nuts lock washers holding the pulleys with a grease fitting on top. If so they uses 6203 bearings you should be able to find cheaper. Share this post Link to post Share on other sites
Stepney 2,354 #3 Posted December 8, 2012 That's the one! Funny, I thought they all had lock washers and 5/8" nuts? At least the Recycler models. Thanks! Spenser. That would be these? http://www.ebay.com/itm/6203-2RS-3-4-Lawnmower-Spindle-Bearings-Toro-Tecumseh-Noma-Dixon-75X40X12-/250913642183?pt=LH_DefaultDomain_0&hash=item3a6b9e56c7 Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted December 8, 2012 You'll need to verify, but Toro/WH part number 109966 is probably what you need: http://www.rcpw.com/...ine/109966.html Unless you enjoy rebuilding mower spindles, spend the money for quality bearings. :handgestures-thumbup: Share this post Link to post Share on other sites
Duff 206 #5 Posted December 10, 2012 Unless you enjoy rebuilding mower spindles, spend the money for quality bearings. Let the congregation put forth a loud AMEN! on that suggestion!!! Duff :thumbs: 1 Share this post Link to post Share on other sites
Forest Road 594 #6 Posted December 13, 2012 If it ain't broke just add more grease! Share this post Link to post Share on other sites
