Torino 15 #1 Posted December 4, 2012 Getting ready to change oil in a kt17. The book says 10w30 below 32F and 30w above. Around here in the winter it can be above 32 one day and below the next. What weight should I use? What about synthetic? Share this post Link to post Share on other sites
1maidenfan 202 #2 Posted December 4, 2012 10w30 will work in both conditions. my :twocents-02cents: Share this post Link to post Share on other sites
Wheel-N-It 2,978 #3 Posted December 4, 2012 Torino, use Lubrication Engineers motor oil. Use 10W 30 until Spring. Then Change to Lubrication Engineers 30W. Is your KT17 a series 1 or series 2? Share this post Link to post Share on other sites
SousaKerry 503 #4 Posted December 4, 2012 I run good old RotellaT-1 30W year round in my KT17-II never have a problem. I have an oil gauge hooked up on my dash and cranking I get 80PSI all year, falls off to around 60PSI when running and warm. Now the transmission is a completely different story, takes a good 10 minutes sometimes to get it operating well in the lower temps. I have on occasion used a heat lamp on the tractor a couple hours before starting it in extreme cold, usually plug it in before going to bed when I know there is going to be an overnight snowstorm. Share this post Link to post Share on other sites
Torino 15 #5 Posted December 4, 2012 It is a series 2. Share this post Link to post Share on other sites
JackC 617 #6 Posted December 12, 2012 "I run good old RotellaT-1 30W year round in my KT17-II never have a problem." Can't go wrong with that. Even better if the engine is worn and using some oil. I find that a strong battery is one of the most important factors for easy starting in cold weather. Share this post Link to post Share on other sites
midnight rambler 36 #7 Posted December 12, 2012 the way oil was formulated back then is a lot different than now. i would run 5w30 in the winter due to the presserised system, the lighter weight oil will get pumped throughout the engine a little faster than the 10w30, i know in the past they were after pressure, now volume is better. i would ask your small engine mech to be sure, im going to put 5w20 in my k341 since im not sure it will sit in the garage or outside. Share this post Link to post Share on other sites
