dsholler 54 #1 Posted December 3, 2012 I just hooked up a rebuilt (new to me) single stage to my 414. I put the pin on the flag in the top hole of the lift bar that faces down (this was correct according to another thread I just saw here).. When I lift the blower, the back edge is only about 2.5 inches above the ground... this seems a bit low to me. I tried tightening the dial-a-height thingy, but that only removed the slack in the lift lever. Did I do something wrong? I also noticed that it seems to lift at a bit of an angle (right sidee, with the crank for the cable comes up first). Dunno if that is a clue... I can probably live with it the way it is, but was wondering if it should not go up higher. Share this post Link to post Share on other sites
rydogg 186 #2 Posted December 3, 2012 I use several thick washers where the flag slides into the lift tube to take up any slack...with the blower in the lowered position you can look under your tractor at the flag and see how much the flag moves into the lift tube before it starts to lift it and shim it accordingly. Not sure if this is the correct way to do it but it works for me. Share this post Link to post Share on other sites
bk-scouter 93 #3 Posted December 3, 2012 I like to use 5 or 6 washers that gets a nice lift for the blower. -BK Share this post Link to post Share on other sites
Wyattrrp 59 #4 Posted December 3, 2012 The owners manuals have a diagram or photo showing several "optional" spacer washers as rydogg says.,Slide them over the solid rod part of the flag before you insert the rod into the tube. The more you have the higher it lifts in effect it lengthens the lift tube. I have I think 5 washers which totals about 3/4 inch in thickness yet it only lifts the bottom of the cutting bar about 3 1/2 inch off the driveway. Share this post Link to post Share on other sites
dsholler 54 #5 Posted December 3, 2012 Hmm, maybe that explains the 3/4 inch bushing I found on the floor of my garage just now.. which seems to be a perfect diameter to slide over the rod. Will put that on tomorrow and see what it does. 1 Share this post Link to post Share on other sites
varosd 1,185 #6 Posted December 4, 2012 The owners manuals have a diagram or photo showing several "optional" spacer washers as rydogg says.,Slide them over the solid rod part of the flag before you insert the rod into the tube. The more you have the higher it lifts in effect it lengthens the lift tube. I have I think 5 washers which totals about 3/4 inch in thickness yet it only lifts the bottom of the cutting bar about 3 1/2 inch off the driveway. Wyattrrp is correct that the snow throwers do not raise up super high. Next, try the snow blade and with the solid A frame, it hits the bottom of the tractor. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #7 Posted December 4, 2012 Proof that newer isn't always better: :ychain: 2 Share this post Link to post Share on other sites
Trouty56 568 #8 Posted December 4, 2012 I also noticed that it seems to lift at a bit of an angle (right sidee, with the crank for the cable comes up first). The pulley tension assembly sort of holds that side up a bit and over time the left side of the thrower will sag a bit. Some sort of spring would help I guess...... Share this post Link to post Share on other sites
Kelly 1,038 #9 Posted December 4, 2012 All the blowers I've had all had a lean, when lifted, some more than others, check the bolts that hold the frame to the blower housing, seen some loose and others missing. Share this post Link to post Share on other sites
dbartlett1958 99 #10 Posted December 4, 2012 The crank side of the blower is going to weigh a bit more also, causing it to hang a bit lower. Share this post Link to post Share on other sites
855ownerJoel 32 #11 Posted December 4, 2012 Proof that newer isn't always better: AHH I see, reading this post I hought, why doesn't it lift higher like mine.... Now I know, mine is an oldie and goodie..... Share this post Link to post Share on other sites
bk-scouter 93 #12 Posted December 4, 2012 Proof that newer isn't always better: but I think it would work a whole lot better if the blower was down on the ground. -BK 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #13 Posted December 4, 2012 It did alright on the ground: but not nearly as good as this one : 1 Share this post Link to post Share on other sites
Lane Ranger 11,976 #14 Posted December 8, 2012 TT that's what I tell my wife about the old snowblower on my 1967 L:awn Ranger. It won't throw the snow 30 feet like the newer ones do but I also don't have to shovel it! 1 Share this post Link to post Share on other sites
