krazy_horse 59 #1 Posted December 2, 2012 I am going to give my C-121 a full tune up for Christmas. What is your opinion is the best spark plug for the big block Kohler? Thanks! krazy_horse Share this post Link to post Share on other sites
squonk 44,859 #2 Posted December 2, 2012 Autolite 216 :thumbs: Share this post Link to post Share on other sites
smoreau 658 #3 Posted December 2, 2012 I use champion H10C plugs in mine. Share this post Link to post Share on other sites
sgtsampay 117 #4 Posted December 2, 2012 I have always used E-3 plugs in mine. I really like how they rarely foul up on me. :) Share this post Link to post Share on other sites
bowtiebutler956 650 #5 Posted December 2, 2012 I am going to give my C-121 a full tune up for Christmas. What is your opinion is the best spark plug for the big block Kohler? Thanks! krazy_horse You sure got alot of different answers. Like Scott, I'm using the Champion H10C in my K301, but thats mostly because it was cheap, and so am I. I tune my equipment up pretty regularly, so I don't buy alot of fancy, expensive parts. That still makes 2 votes for the H10C. Matt :flags-texas: 2 Share this post Link to post Share on other sites
Kelly 1,035 #6 Posted December 2, 2012 Can't think of the no. off the top of my head, but I like NGK, or Autolite. 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted December 2, 2012 I use Autolite plugs in everything but the Yamaha carts and the Stihl equipment at work. (they get NGK plugs) Share this post Link to post Share on other sites
MaineDad 87 #8 Posted December 2, 2012 Autolite 216 here too Share this post Link to post Share on other sites
varosd 1,185 #9 Posted December 3, 2012 Champion or whatever is on sale...I'm cheap (thrifty) too, Matt! :rolleyes: 1 Share this post Link to post Share on other sites
Tankman 3,523 #10 Posted December 3, 2012 I use champion H10C plugs in mine. Using the same Champion plug on four Kohlers. RH10C. Manual called for the RH10 but, don't think it is still available. The "C" stands for copper core. Plugs hold up well in my 12, 14 & 16 hp Kohler engines. http://www.sparkplug-crossreference.com/convert/CHAMP_PN/RH10C Presently thinkin' of a roller for my gravel. :-) 1 Share this post Link to post Share on other sites
gregg'shorses 77 #11 Posted December 4, 2012 Champion H10C Share this post Link to post Share on other sites
bowtiebutler956 650 #12 Posted December 4, 2012 That makes 5 votes Champion, 4 Autolite, 1 NGK, 1 E3. The Campion plugs are the champion! Matt :flags-texas: 1 Share this post Link to post Share on other sites
Wheel-N-It 2,976 #13 Posted December 4, 2012 Copper core all the way. The high tech plugs are for high tech ignition systems. The high tech plugs are good, but you have to have alot of voltage to fire them correctly. You will get better spark from an old Kohler if you use the low tech copper core spark plugs. And you will save money :) 5 Share this post Link to post Share on other sites
rick 258 #14 Posted December 5, 2012 Kohler says Champion H10, so......... 1 Share this post Link to post Share on other sites
pumper.atv 26 #15 Posted December 6, 2012 i run champions in all our kohlers (10) Share this post Link to post Share on other sites
"D"- Man 827 #16 Posted December 6, 2012 Chapion H10C IN MINE. Share this post Link to post Share on other sites
JC 1965 1,534 #17 Posted December 6, 2012 I used champion in all my tractors but I got some about 2 years ago that were crap. So I switched to Autolite and have been using them ever since. :twocents-02cents: 2 Share this post Link to post Share on other sites
specialwheelhorse 174 #18 Posted December 7, 2012 Years ago when racing dirt track cars we stumbled on what was called at that time AC-commercial plugs, dont even know if they are available anymore. But they beat every other plug hands down. Heavy electrods and no problems at any RPM range. Jim In Texas Share this post Link to post Share on other sites
smoreau 658 #19 Posted December 7, 2012 Copper core all the way. The high tech plugs are for high tech ignition systems. The high tech plugs are good, but you have to have alot of voltage to fire them correctly. You will get better spark from an old Kohler if you use the low tech copper core spark plugs. And you will save money You took the words right out of my mouth, well said!! 1 Share this post Link to post Share on other sites
pfrederi 19,241 #20 Posted December 8, 2012 Anything but Champion. A few years ago spent a great deal of time trying to find out why my Charger 12 wouldn't start. I had put in a Champion plug and a few weeks later she balked at starting. Laid the plug on the head and cranked her and got a spark so I spent alot of time fiddling with carb and looking at the points. Then dug out my spark plug tester and low and behold no spark when the plug was installed. Apparently it wouldn't fire when under compression. Last year my C-81 balked at starting it also was a Champion that failed to fire reliably under compression. Share this post Link to post Share on other sites
tunahead72 2,587 #21 Posted December 10, 2012 I'm currently using an Autolite 216 and a Champion H10C in my two Wheel Horses, and can't really see any difference in the way they run (at least that I can attribute to differences between the spark plugs). I started switching to Autolites a few years ago, starting on my truck, when I realized I'd been hearing "Champions suck" stories for a long time. I've heard differently recently, independently from two auto parts dealers that I use on a regular basis. They both told me that Champion did indeed have a reputation for many years for poor quality control (stripped threads, cracked insulators, etc.). But apparently they've improved greatly recently, and both guys told me they now have very few problems with the Champions they sell. I wasn't sure I bought the first dealer's comments, but after hearing the same story from the second, it's now a toss-up for me between Autolites and Champions. But I'm always learning.... The NGK's on the other hand, I've always heard excellent reports on them. Right now I won't use anything else on my (Japanese) motorcycle, and I'll at least consider using them on my Wheel Horses in the spring. Share this post Link to post Share on other sites
Bluffhunter 37 #22 Posted May 24, 2013 I still have a box of Autolite 216's from my old Allis Chalmers tractor, so I will see if my C-161 likes them Share this post Link to post Share on other sites
Earle 3 #23 Posted May 24, 2013 I'm old, my first car was a 1941 Plymouth 4dr, had one 1955 ford, 3 1956 fords, 1956 buick roadmaster 4dr hardtop, don't remember some of the cars I had too many, but I always tried to use Champion once in a while AC (After Champion).They probably make a lot better ones now. Earle Share this post Link to post Share on other sites
boovuc 1,090 #24 Posted May 27, 2013 My vote is for Autolite as well. They seem to hold up much better overall than the Chamoions. NGK's are a distance 2nd mostly on availability and not in performance. Share this post Link to post Share on other sites
Fordiesel69 271 #25 Posted May 29, 2013 #1 Champion H10C #2 Autolite 216 NGK's get used in all 2 stoke equipment of mine. Autolites get used in each and every push mower as champion small engine plugs are absolute trash now. Champions larger plugs J8C and bigger are still good. I have a local motorcycle shop that has older NGK and Champions from the 1980s' and 90's that I buy. Share this post Link to post Share on other sites
