rmaynard 17,582 #1 Posted December 2, 2012 My K161-28522 has the two piece camshaft, without ACR. Is there any reason why I can't install a camshaft with ACR? Share this post Link to post Share on other sites
buckrancher 2,697 #2 Posted December 2, 2012 no but why do you want too both camshafts do the same thing only using different approachs for ease of starting Brian Share this post Link to post Share on other sites
rmaynard 17,582 #3 Posted December 2, 2012 I had someone offer me an ACR camshaft (NOS), reasonably priced. I really don't need it, but was just curious about interchangeability. Share this post Link to post Share on other sites
buckrancher 2,697 #4 Posted December 2, 2012 (edited) you could buy it and keep it in stock I'm sure you will find a use for it someday Bob For those who do not know the older style camshaft ( two piece) retards the ingition timing for ease of starting The ACR style releaves some compression for ease of starting Both styles are for manual recoil starting not for electric start Both styles use flyweights attached to the back of the gear on the camshaft to operate The older two piece style retards the ignition spark to fire after top dead center this makes the motor easier to pull start once the engine fires the speed of rotation throws the flyweights out on the back of the cam gear and rotates the point cam lobe to advanced position or before top dead center the acr camshaft uses weights to hold a small tab on the valve cam lobe to keep the exhaust valve open a crack until just about top dead center of the piston stroke to remove most of the engines compression when the engine starts the speed of rotation throws the flyweights out and drops the small tab holding the exhaust valve up on compression stroke to give the engine it's full compression Brian Edited December 3, 2012 by buckrancher 1 Share this post Link to post Share on other sites
dbartlett1958 99 #5 Posted December 3, 2012 Brian, That was a GREAT explanation. Thank you. David Share this post Link to post Share on other sites
specialwheelhorse 174 #6 Posted December 3, 2012 Just wish I could explan things that well !!! The old goof from Texas JIM Share this post Link to post Share on other sites
