Torino
Crap!!! Forgot to install carb baffle.
Torino
Cleaning the carb on my kt17 and got the carb back on and was cleaning up and found that I forgot to install the baffle in the carb. What does this do? Should I tear it down again and install?
smoreau
That's more of a issue on inclines and hills for the most part. I have found on some carbs for Kohlers I intently leave them out. Most of the time I put them in but on the rare accusation that I cant get it to run just wright, I will remove them.
Edited by smoreau
sorekiwi
I have a K181 on a Lawn Ranger here that is without the baffle.
It runs fine 99% of the time, even on the slopes in my yard. But there is one spot where a drainage swale has sunk down a bit, the carb gets a gulp of extra fuel when I hit that and it coughs a bit over the bump. One day I'll get around to refitting it, but its been a couple of years without it now.
rmaynard
The carburetor on one of my B-100's does not have a baffle. I had a problem where the baffle got stiff and bowed down, keeping the float from rising completely. This caused the engine to flood because the float valve was not closing completely. I simply took out the baffle and had no further issues.
Torino
Since it is already on the tractor ready to go I will go ahead a try it without it.
