55farmall 0 #1 Posted November 29, 2012 This is first time mounting a snow blade on my 520hc does the mule drive need removed on can it stay. Share this post Link to post Share on other sites
Foozerush 40 #2 Posted November 29, 2012 Take it off... Share this post Link to post Share on other sites
Tankman 3,526 #3 Posted November 29, 2012 Oh yeah, take it off, hang it in the shed. Share this post Link to post Share on other sites
55farmall 0 #4 Posted November 29, 2012 Ok sounds good how hard is it to remove Share this post Link to post Share on other sites
Foozerush 40 #5 Posted November 29, 2012 Easy.... 1 turn knob to loosen tention to belt, 2 disconnect the PTO engage ( the spring clip on the half moon bar that goes around PTO, and the clip on the bracket below the muffler), 3 swing the half moon bar away from the PTO and remove belt, and put back together, then on the right side of the mule drive is a rod with a rubber end on it, push it in, and on the bottom on the right is a metal tab pointing down, just pull it towards you and the mule drive will pop out of the hooks it sits in. Hope this helps. Share this post Link to post Share on other sites
Sparky-(Admin) 24,119 #6 Posted November 29, 2012 This might help with the mule drive removal. Mike......... Share this post Link to post Share on other sites
KC9KAS 4,745 #7 Posted November 29, 2012 55farmall.... :WRS: Share this post Link to post Share on other sites
Shuboxlover 484 #8 Posted November 30, 2012 Do you have the plow extension brackets on the blade??? Share this post Link to post Share on other sites
55farmall 0 #9 Posted December 3, 2012 Well since I work at a sheetmetal shop I cut and extended it . I know this isn't the recommend way but it was the cost efficient for me since I only paid 90 for the blade Share this post Link to post Share on other sites
