P3x 57 #1 Posted November 26, 2012 Can anyone tell me the diameter and length of the Blade Pivot Bolt and Nuton a 79350 Dozer/Plow (1995)? Went to mount my plow and frame as snow is in the forecast. Found the nut missing and the bolt currently in the pivot mount shortened a tad. But may be the Toro bolt. Looks to be 3/4 or 7/8 Diam. with fine threads. Went to the local HD during lunch and they did not have anything bigger than 1/2 Diam. The Toro PN is 3216-7-Screw-HH for the Bolt and 3296-15-Nut-Lock,NI for the nut. Thank you! p3x Share this post Link to post Share on other sites
Wyattrrp 59 #2 Posted November 26, 2012 In the Toro manual for the 79350 Ser No 5900001 and up as well as in a 1990 06-48BC02 model manual, the same bolt is listed for each as being a 3/4-16 x 3 3/4" with a 3/4-16 nut. Go to Toro Parts Viewer webpage and enter 79350 then for your year or Ser No. Click the Buy From Toro link. Next at page bottom should be an instruction manual which you may be able to download by cli9cking the link. Heck even a 1961 and 1965 manual in the Manuals section here on this site list the same size bolt so it must have been on many many years of blades by WH and Toro. Share this post Link to post Share on other sites
P3x 57 #3 Posted November 26, 2012 Now why did'nt I think of doing that! Thanks for the info Wyat. I'll see if my local Hrdwr store has one on the way home from work. Share this post Link to post Share on other sites
1054josh 25 #4 Posted November 26, 2012 I got mine at fastenal. They actually had it in stock and a grade 8 at that Share this post Link to post Share on other sites
