tractorbeast 27 #1 Posted November 25, 2012 I picked up an 1983 K301QS, Kohler engine with dual horizontal shafts. Would someone have an idea about what this engine might have been used for? Pulley setup on the correct side for use in a wheel Horse 1980's C Series. The opposite shaft has a approx. 4" round plate on it with several mounting holes in it. Sorry I didn't get a pic of it yet. It has a lot bigger muffler on it, I'm assuming that's why its a "Quite Model". Share this post Link to post Share on other sites
tunahead72 2,581 #2 Posted November 25, 2012 Do you have a spec number for this engine? Share this post Link to post Share on other sites
Don1977 605 #3 Posted November 25, 2012 Tillers used the extra shaft from the cam for reverse as it turns in the ob-sit direction, but I have never seen 12 HP Kohler on a tiller. My guess is that it was used to reverse something. Share this post Link to post Share on other sites
baerpath 517 #4 Posted November 25, 2012 Could be a cub. Jacobson / Ford one crank side for deck flywheel side to drive the tractor Share this post Link to post Share on other sites
tractorbeast 27 #5 Posted November 25, 2012 Do you have a spec number for this engine? the spec# for this engine is 47606. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted November 25, 2012 It's from a Jacobsen. Later models drove the tractor off the flywheel and the PTO mounted to the PTO end of the crankshaft. Share this post Link to post Share on other sites
