Teddy da Bear 11 #26 Posted August 1, 2008 Thanks Burly.... Your always looking out for us. B) Share this post Link to post Share on other sites
big mike 13 #27 Posted August 1, 2008 No problem Mike,just offerin a hand if I can B) Share this post Link to post Share on other sites
Teddy da Bear 11 #28 Posted August 1, 2008 Just curious Mike....how far away are you? Share this post Link to post Share on other sites
big mike 13 #29 Posted August 1, 2008 I'm on either side I live on the east side of Beebe farms Share this post Link to post Share on other sites
Teddy da Bear 11 #30 Posted August 3, 2008 Anyone able to show me what the rear tail light was suppose to look like???? Share this post Link to post Share on other sites
Brrly1 1,146 #31 Posted August 3, 2008 Hey Teddy It looks like a small bullet type light. Ebay occasionally but they ar expensive. I am also looking for one, Good Luck Burly Share this post Link to post Share on other sites
Teddy da Bear 11 #32 Posted August 3, 2008 Thanks John, I had a feeling it would be something like a "bubble". I will see what I can come up with. Share this post Link to post Share on other sites
Teddy da Bear 11 #33 Posted August 6, 2008 Came up against a small problem. I adjusted the brake band. But I still cannot shift gears with the engine running. I took off the belt guard and observed the tensioning pulley when the foot peddle is depressed. It slackens the belt, but perhaps not enough. The tractor wants to take off anyway. I do not think the belt itself is too small. I wonder if there is suppose to be more "travel" in this tensioning pulley bracket? Is the pulley suppose to clear (drop below) the belt path entirely? The tensioning pulley still touches the belt on my tractor. Did somone stomp on the brake/clutch peddle and bend something?? Any advice would be appreciated. Share this post Link to post Share on other sites
Brrly1 1,146 #34 Posted August 6, 2008 Hey Teddy Take some pictures and I will compare to mine and let you know.But probably some of these guys might be able to tell you just by looking at it. I believe the belt #'s are 1591 for the Hyd. belt and 1592 for the drive belt and 1593 for the starter generator belt. These #'s are the Wheel Horse #'s. Every so often you see these come up on ebay. See ya Burly :horseplay: :horseplay: Share this post Link to post Share on other sites
Teddy da Bear 11 #35 Posted August 6, 2008 Ok....first shows belt under normal tension. Attached Image Share this post Link to post Share on other sites
Teddy da Bear 11 #36 Posted August 6, 2008 Here is the belt position when clutch peddle is fully depressed. Note that belt is slack, but still touching tensioning pulley. Attached Image Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #37 Posted August 6, 2008 The "finger" is missing from the back of the tensioner pulley. (go look at the parts drawing - it's part no. 6360) Without the tab to pinch the belt, it won't lift off of the engine pulley enough to declutch. Share this post Link to post Share on other sites
Teddy da Bear 11 #38 Posted August 6, 2008 Terry....I see the part your refering to. It looks like I could make one if someone like Burly could get me some measurements and a picture of it's orientation on that pulley. I know it likely reaches out over the width of the pulley, but I do not know how far above the pulley the bent part of the finger sits. And from an engineering standpoint I do not see how this could work. Given the direction the pulley moves when the clutch peddle is depressed.....it seems like it would pinch/tighten the belt further when the tensioning pulley moved down. Need picture of this if someone can do that. Thanks Share this post Link to post Share on other sites
Duff 206 #39 Posted August 7, 2008 And from an engineering standpoint I do not see how this could work. Given the direction the pulley moves when the clutch peddle is depressed.....it seems like it would pinch/tighten the belt further when the tensioning pulley moved down. Mike, I know it seems bass-ackwards, and I thought the same thing when I was putting my 312-8, which has a roughly similar set-up, back together. Turns out, if I see/understand the situation correctly, the "finger" TT is referring to also acts a belt "brake" so the belt stops moving when you declutch so you can shift without grinding the gears. Am I on the right track, guys? Duff B) Share this post Link to post Share on other sites
Teddy da Bear 11 #40 Posted August 7, 2008 I think I can picture that action Duff.....thanks. Now to fabricate something that works. I would still love to see a picture of it on the tractor. Share this post Link to post Share on other sites
Teddy da Bear 11 #41 Posted August 8, 2008 No one willing to take a belt cover off for a picture? Awwwwwwwwww.... Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #42 Posted August 8, 2008 Your signature says you have 5 other gear-drive tractors..... Can't you just look at one of those? (they all work the same way.) Share this post Link to post Share on other sites
Teddy da Bear 11 #43 Posted August 8, 2008 Sorry I was so naive. I thought most of the 1054 was unique to that tractor. Thanks. Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #44 Posted August 8, 2008 The parts are unique to the 953/1054, (the whole tractor is actually unique) but the belt finger works the same on all tractors. It fastens to the back side of the tensioner arm with the same bolt that secures the V idler. On the newer models, the finger is actually welded to the tensioner arm in a fixed position. Never bend the finger to remove the belt - always unbolt the V idler. Share this post Link to post Share on other sites
Teddy da Bear 11 #45 Posted August 8, 2008 I got one made...... Darned if I know if it works or not. Thought I would try to address the throttle linkage issue and I made a bigger issue of it by breaking a half inch off near the lever. Went to buy a cable and they said they don't sell raw cable. I will wait until the swap meet in Portland to get one. Share this post Link to post Share on other sites
big mike 13 #46 Posted August 9, 2008 Mike,could you get a cheap cable locally and fix yours? Share this post Link to post Share on other sites
Teddy da Bear 11 #47 Posted August 9, 2008 Mike.....you likely have the right idea. I just needed some time to think about it and see if it was possible to alter an existing cable. Share this post Link to post Share on other sites
linen beige 14 #48 Posted August 9, 2008 Went to buy a cable and they said they don't sell raw cable. Maybe "they" don't, but someone does. Check with a real hardware store. It comes in rolls, just like electrical wire, chain, rope, etc. And in more than one size. Just make sure you get both an outside sheath, AND the inside wire. Share this post Link to post Share on other sites
Teddy da Bear 11 #49 Posted August 9, 2008 Jim....C&C of South Bend is a Kohler engine parts dealer. They did have raw cable but asked me if I wanted to buy a 50ft. roll.... I will give the true value store a call.....thanks. Share this post Link to post Share on other sites
linen beige 14 #50 Posted August 9, 2008 Jim....C&C of South Bend is a Kohler engine parts dealer. They did have raw cable but asked me if I wanted to buy a 50ft. roll.... I will give the true value store a call.....thanks. It's been a few years since I bought a roll, but if you figure say, five feet per cable, two cables per tractor, it works out to only five tractors a roll. If a fifty foot roll aint too steep, then it may be worth it to replace ALL the old rusted cables on five or so tractors? Share this post Link to post Share on other sites
