jgun45879
Carb. Repair...
jgun45879
Hi, I have a 1988 310-8 that needs the carb. throttle shaft repaired. Where is the best place to buy a shaft re-bushing repair kit?
Thanks for any help. Jim.
Kelly
This is a cheap kit on ebay, here is the item no. 300746960478 or you can buy the kit from Kohler that has a new shaft and other parts but you have to drill the body out to use those kits.
whc160
NAPA sells the Kolher kit & they have a kit in the NAPA small engine line.
joel_400
I use bushings from lakota racing when I do them. I just remove the throttle arm from the shaft by grinding the peened over end off very carefully. Then the bushing slides down over the shaft and sits in the recessed area right below the throttle arm. Then comes the fun part...drilling the shaft. It really isnt bad though. Just drill and tap the shaft to hold the throttle arm back down. For most carb this does a wonderful job.
Joel
Anglo Traction
Yeah, What Kelly says. Used them for the 3 that I've done. Save having to remove the Throttle Arm that Joel mentioned, but you need to be careful removing the old Throtte Plate Screws without breaking . There are several threads here on the practice.
buckrancher
Brian Miller sell bushing kits also
