VinsRJ 724 #26 Posted November 27, 2012 Just a little tid bit, next time PM your email addy to a member... that way the entire World Wide Web doesn't get a hold of your email. Share this post Link to post Share on other sites
KEN NABER 28 #27 Posted November 27, 2012 thanks, just changed that Share this post Link to post Share on other sites
VinsRJ 724 #28 Posted November 27, 2012 thanks, just changed that I just removed the quote from my post with your addy in it. I appologize for that. Share this post Link to post Share on other sites
KEN NABER 28 #29 Posted December 3, 2012 Up and running !! replaced all wires!! did the trick!! original flywheel worked !! Thanks to all !! Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #30 Posted December 3, 2012 Good to hear! :handgestures-thumbup: 1 Share this post Link to post Share on other sites
dmoore 1,042 #31 Posted February 25, 2025 I know this is an old thread but I'm having the same issue with my RJ-58. Did I read this correctly? Buckrancher sent him another used flywheel which fixed the problem? Weak magnet?. Share this post Link to post Share on other sites
oliver2-44 11,751 #32 Posted February 25, 2025 @dmoore I read it as he used his original flywheel but replaced All the wires between the coil, points etc. I guess he had a bad wire between the coil and points. Share this post Link to post Share on other sites
dmoore 1,042 #33 Posted February 25, 2025 Gotcha! Thanks! Share this post Link to post Share on other sites
