dodge78 94 #1 Posted November 19, 2012 Does spacer #112824 get welded to the axle or is it supposed to be held in by the bearing? The spindles I got look like the spacer spun and wore a groove into the vertical part of the bracing. I am putting trailer spindles on if that makes a difference. Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted November 19, 2012 They just slide on the spindle, I know because fri. I pulled a front wheel off a 520 and the spacer fell on the ground. Share this post Link to post Share on other sites
smoreau 658 #3 Posted November 20, 2012 you will need the spacer for the seal to ride on. They are still available and I think I paid about $4 for each. Share this post Link to post Share on other sites
