Lars 526 #1 Posted November 17, 2012 Well i have got an idea so i just had to test it out to see if it works.. I have installed an electric winch on my raider 10 to lift the snowblade/blower/deck and also the rear hitch.. i have put it where the battery is on it so i have to put the battery under the seat on it:) Here are some pict of it so far.. and a small vid of how it lift.. Thanks Lars 3 Share this post Link to post Share on other sites
Jake Kuhn 1,581 #2 Posted November 17, 2012 very good idea lars! where did you hide the battery, under the seat? Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted November 17, 2012 I bet you could tear the bell crank right out of the dash with that!!!!! Share this post Link to post Share on other sites
Lars 526 #4 Posted November 17, 2012 I bet you could tear the bell crank right out of the dash with that!!!!! yeah i think so too Kelly.. Im going to test it to see if it works good.. if it does im going to put on some safetyswitch on it so it cuts the power when it's liftet up to top Share this post Link to post Share on other sites
HorseFixer 2,013 #5 Posted November 17, 2012 Pretty Cool Lars Looks like that Aught to get the Job Done! How many Pound winch is that Puppy? ~Duke Share this post Link to post Share on other sites
AMC RULES 37,232 #6 Posted November 17, 2012 That thing is fast too. Share this post Link to post Share on other sites
Lars 526 #7 Posted November 17, 2012 (edited) Pretty Cool Lars Looks like that Aught to get the Job Done! How many Pound Winch is that Puppy? ~Duke Thx Duke.. yeah i looks like that.. the Puppy is 2000 LBS.. but im not sure on that LOL Lars Edited November 17, 2012 by Knusern Share this post Link to post Share on other sites
Lars 526 #8 Posted November 23, 2012 Hey fellas i have now got the battery under the seat pan and i have wired up the winch.. and it works great. going to take it apart again and paint the parts i have put on it.. and the best of all i have not made any other holes in my horse to get it one.. Wohoooooo Thanks Lars 2 Share this post Link to post Share on other sites
groundhog47 347 #9 Posted November 23, 2012 Lars, You do excellent work, oustanding idea as is the safety switch!! Neat control location also! Put you a roller/pulley underneath to mid hitch (loop over forward or backward whichever you extend out hook around roller)and have a self extractin' pull out device if you get stuck also. Share this post Link to post Share on other sites
neil 2,410 #10 Posted November 23, 2012 ingenious Lars, I like ground hogs idea too Share this post Link to post Share on other sites
Stigian 1,234 #11 Posted November 24, 2012 That's a neat idea Lars, a push button blade control is very cool Nice welding by the way. 1 Share this post Link to post Share on other sites
Lars 526 #12 Posted November 28, 2012 Lars, You do excellent work, oustanding idea as is the safety switch!! Neat control location also! Put you a roller/pulley underneath to mid hitch (loop over forward or backward whichever you extend out hook around roller)and have a self extractin' pull out device if you get stuck also. yeah i have had it in my mind.. but it is a bit thight down there.. ingenious Lars, I like ground hogs idea too yep that is not a bad ide.. That's a neat idea Lars, a push button blade control is very cool Nice welding by the way. Thanks bud Share this post Link to post Share on other sites
groundhog47 347 #13 Posted November 29, 2012 Hey, Lars, if you have another you are going to fabricate and need a 12v dc gear motor (off ambulance wheel chair lift) have two not using, may be slower lifting. Will check out and photograph tomorrow. Share this post Link to post Share on other sites
neil 2,410 #14 Posted November 29, 2012 Lars ,could you get a remote control fitted to the winch I was looking at a remote control winch set up myself a while ago and it wasnt too much money neither. Share this post Link to post Share on other sites
Lars 526 #15 Posted November 29, 2012 Hey, Lars, if you have another you are going to fabricate and need a 12v dc gear motor (off ambulance wheel chair lift) have two not using, may be slower lifting. Will check out and photograph tomorrow. well i always have some projects.... so it might be somthing ill can use.. Lars ,could you get a remote control fitted to the winch I was looking at a remote control winch set up myself a while ago and it wasnt too much money neither. Im not sure if i can get it to this modell.. i was looking at one whit remote on but the winch they had there was bigger then the one ill got.. but i was thinking of put one on my trailer to get it dump.. so i might going to use one whit remote there.. Share this post Link to post Share on other sites
groundhog47 347 #16 Posted November 29, 2012 Hey, Lars, if you have another you are going to fabricate and need a 12v dc gear motor (off ambulance wheel chair lift) have two not using, may be slower lifting. Will check out and photograph tomorrow. Inconsequential and possibly imaterial, photo of moter 1750 rpm, 40:1 ratio, approximately 15" long (tag says 35 but that doesn't calculate ?1400rpm). Share this post Link to post Share on other sites
KC9KAS 4,744 #17 Posted November 29, 2012 Don't knock yourself in the head with the implement lift handle while using the winch. I noticed it moving back and forth very quickly. Share this post Link to post Share on other sites
Anglo Traction 761 #18 Posted November 30, 2012 Excellent job Lars ! , Don't knock yourself in the head with the implement lift handle while using the winch. I noticed it moving back and forth very quickly. Good point....maybe fab up a Stubby Lever & Rock Shaft and remove the Lift Lever Ass'y ?, 1 Share this post Link to post Share on other sites
tmix 34 #19 Posted December 26, 2013 Thanks great idea Share this post Link to post Share on other sites
Olratlr 25 #20 Posted January 7, 2014 You done real good Lars. Share this post Link to post Share on other sites
