truckin88 104 #1 Posted November 11, 2012 My dads 520 runs good, starts good cold. But after running if you shut off and go to restart within about 20 minutes of running she will not start.....let it sit for a while she fires right up....she charges fine....issue with carb? Share this post Link to post Share on other sites
JackC 617 #2 Posted November 11, 2012 Could be either the carb, a heat induced electrical problem, or fuel pump. I would check for spark when you try to re-start when hot. If you have spark, then suspect carb or fuel pump. What year is it and what is the spec number on the engine? Some of the newer ones have the emissions carburetor that they recommend replacing rather than cleaning. I would still try to clean it first by dissembling it and soaking it in carburetor cleaner. If I were replacing the carburetor I would find a non emissions carburetor. Others most likely have run into the same problem and will offer advice. Share this post Link to post Share on other sites
truckin88 104 #3 Posted November 11, 2012 It is a 96, new ngk plugs, new plug wires. Sat for a while only 233 hrs. Share this post Link to post Share on other sites
KEN NABER 28 #4 Posted November 11, 2012 truckin88 my 1927 chevy did that and ended up being coil Ken Share this post Link to post Share on other sites
