Cutlas3391 776 #1 Posted November 7, 2012 This will be my first project for the winter its a raider thats been sitting outside it whole life. I got the raider running after 10 years of sitting but needs a lot of TLC.... Share this post Link to post Share on other sites
Pollack Pete 2,273 #2 Posted November 7, 2012 Nice.I don't think it looks bad.It looks better than most of mine.Have fun with your new toy. Share this post Link to post Share on other sites
CTPhil 53 #3 Posted November 7, 2012 How far are you going to go? Paint and everything? Share this post Link to post Share on other sites
AMC RULES 37,196 #4 Posted November 7, 2012 Nice...tiller, weights, and a snow blade too. Share this post Link to post Share on other sites
KATO 115 #5 Posted November 7, 2012 a little rusty maybe but looks like a solid machine to start with except for the seat. Lots of pics please Share this post Link to post Share on other sites
KC9KAS 4,744 #6 Posted November 7, 2012 Looks like a good tractor to fix up. What size is it? I have a Raider 12 that looks about the same, but very solid and runs good! Share this post Link to post Share on other sites
JackC 617 #7 Posted November 7, 2012 Looks good just as it is. The weather wear gives it character. You could polish it up with some WD40 put a good seat on it, make sure the mechanicals and electricals are in order and be good to go. Share this post Link to post Share on other sites
Cutlas3391 776 #8 Posted November 7, 2012 Probably do a soft restore ct Phil. It's a 12hp kc9kas I have a couple other raiders for parts that have the same engine. Share this post Link to post Share on other sites
can whlvr 994 #9 Posted November 7, 2012 its nice to have a parts tractor or 2 when doing a restore Share this post Link to post Share on other sites
Jake Kuhn 1,579 #10 Posted November 8, 2012 looks like a nice starter. Can't wait to see some progress on it! Share this post Link to post Share on other sites
Racinbob 11,919 #11 Posted November 8, 2012 If I'm not mistaken, that's an older style tiller needing two belts to operate and a different hitch bolted to the real axle. It's an easy conversion to go to the later style drive system with only one belt. It makes it much easier to put on and the tines move just a tad faster due to the pulley ratios. You have a mid mount pulley gizmo that you have to put on, right? Share this post Link to post Share on other sites
bowtiebutler956 650 #12 Posted November 8, 2012 That looks like a very solid old Raider, and a great candidate for a resto. Nice Save! Matt :flags-texas: Share this post Link to post Share on other sites
Cutlas3391 776 #13 Posted November 8, 2012 If I'm not mistaken, that's an older style tiller needing two belts to operate and a different hitch bolted to the real axle. It's an easy conversion to go to the later style drive system with only one belt. It makes it much easier to put on and the tines move just a tad faster due to the pulley ratios. You have a mid mount pulley gizmo that you have to put on, right? Yea it's a 2 belt pulley system I also have 2 Prather tillers I might swap out to the one belt How far are you going to go? Paint and everything? Probably going to due a soft restore. Share this post Link to post Share on other sites
Cutlas3391 776 #14 Posted November 8, 2012 Looks good just as it is. The weather wear gives it character. You could polish it up with some WD40 put a good seat on it, make sure the mechanicals and electricals are in order and be good to go. I keep hearing about the Wd-40 bath how does that exactly work? Share this post Link to post Share on other sites
krazy_horse 59 #15 Posted November 8, 2012 You rub the tractor down with fine (00) steel wool then wipe down with WD-40 or at least that is the way I did a couple of mine. Gives them that used but took care of look. By the way I like your tractor combo! 2 Share this post Link to post Share on other sites
JackC 617 #16 Posted November 8, 2012 WD40 will clean and brighten the finish. Try it on a spot somewhere first like under the seat. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #17 Posted November 11, 2012 You rub the tractor down with fine (00) steel wool then wipe down with WD-40 or at least that is the way I did a couple of mine. Gives them that used but took care of look. By the way I like your tractor combo! Cutlas, give us a before and after pic of the WD40 bath method. I love WD40, and buy it buy the gallon. 1 Share this post Link to post Share on other sites
AMC RULES 37,196 #18 Posted November 11, 2012 Take it from Rachael, a little EVOO and some croutons will work in a pinch too. Share this post Link to post Share on other sites
Tankman 3,523 #19 Posted November 13, 2012 You rub the tractor down with fine (00) steel wool then wipe down with WD-40 or at least that is the way I did a couple of mine. Gives them that used but took care of look. By the way I like your tractor combo! Cutlas, give us a before and after pic of the WD40 bath method. I love WD40, and buy it buy the gallon. I use the WD-40 (WD = water displacement) almost daily. And, I like my Singer sewing machine oil can too! Keepin' my Raider 12 forever! Great Stallion! Share this post Link to post Share on other sites
kris22 6 #20 Posted November 16, 2012 Nice looking tractor im partial to the original look myself and im glad to know im not the only one that puts atv tires on a wh Share this post Link to post Share on other sites
