rmaynard 16,543 #1 Posted November 6, 2012 (edited) I have a governor gear that seems to have a bit of wobble and I would like to remove it. Does the Welch plug need to be removed in order to get the gear out? I am assuming that it does. This subject is not covered in the Kohler manual. Also, the manual does not cover the engine (28522E) which has the 2-7/8" piston. My question is, other than the bore and piston size, are all the other specifications the same? Okay, ignore the first part of the question, I found out how to remove the gear without Welch removal. However, the second part of the question still remains concerning the specs. Edited November 6, 2012 by rmaynard Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted November 6, 2012 I can't think of any differences in early vs. late K-161 engines other than the bore size and the style of camshaft used. (two-piece spark advance vs. ACR) Share this post Link to post Share on other sites
rmaynard 16,543 #3 Posted November 6, 2012 Yup, I noticed how the cam fell into two pieces when I removed it. That info is in the Kohler manual, so there was no surprise. Share this post Link to post Share on other sites
