Butch 194 #1 Posted November 5, 2012 Yep, now my hydraulic lift is raising my deck on it's own. You can be mowing the lawn and up it comes. It's a C-175 automatic. Any ideas what's causing this? Thanks! Share this post Link to post Share on other sites
squonk 44,973 #2 Posted November 5, 2012 Mine did that a few times and then quit doing it. Has to be something with the lift valve. :confusion-scratchheadblue: Share this post Link to post Share on other sites
SousaKerry 503 #3 Posted November 5, 2012 Yeah definitely the spool sticking or leaking. Can be a real pain to get out but should be rebuildable. Take it out clean it first, disassemble clean it again, put in new o-rings, reassemble. Then the fun begins putting it back in... It is at least a 5 cuss word job. Take care not to get any dirt in the hydraulic lines. Share this post Link to post Share on other sites
Butch 194 #4 Posted November 5, 2012 I did rebuild it 2 years ago and even replaced the lines with much stiffer ones. It was very hard to put back together! Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted November 5, 2012 It could be that the bore inside the valve body is scored or the spool itself is scratched allowing build to seep past the seals. I personally have not disassembled a WH spool valve but have done many industrial ones at work. Some spools do not have o-rings and seals they rely on very tight tolerances and a thin film of oil to seal. Any wear on this type and they are junk, you may want to source a good used one to see if you still have the problem. Share this post Link to post Share on other sites
Butch 194 #6 Posted November 5, 2012 It could be that the bore inside the valve body is scored or the spool itself is scratched allowing build to seep past the seals. I personally have not disassembled a WH spool valve but have done many industrial ones at work. Some spools do not have o-rings and seals they rely on very tight tolerances and a thin film of oil to seal. Any wear on this type and they are junk, you may want to source a good used one to see if you still have the problem. Thanks. Share this post Link to post Share on other sites
