RJR49 159 #1 Posted November 2, 2012 C-160 but they are all pretty much the same. My ignition switch is pretty worn out so I grabbed my needle nose pliers to remove one wire at a time to transfer to the new switch. Who would have thought that when I pulled the switch out of the dash ALL the wires came off! Screwed! I have the C Series manual but the picture of the ignition switch doesn't clearly define the terminals. If anyone has a better schematic or lives near Cheshire Connecticut so I can look at yours I would appreciate some help. I haven't scoped this out yet but there are 5 wires off the switch. Share this post Link to post Share on other sites
rmaynard 16,991 #2 Posted November 2, 2012 I believe this might be what you are looking for. This is for a B-100 that does not have lights. The empty hole is for the lights (accessories). Be sure that you have the correct replacement switch. They are all NOT alike. Share this post Link to post Share on other sites
Anglo Traction 761 #3 Posted November 2, 2012 Your Ignition Switch is a 3 position (off/run/start), 5 Pin, Part number 103990. I assume there is no Connector Block holding the wires in their respective places. I have a diagram somewhere, but I'm sure someone will beat me to it. Share this post Link to post Share on other sites
RJR49 159 #5 Posted November 3, 2012 Old iron That's perfect! Randy P.S I have a couple of rear tires in pretty good shape if anyone wants them Share this post Link to post Share on other sites
