cmglis02
Reverse on a RJ-35
cmglis02
I have a 1957 Wheelhorse RJ-35 im restoring and was wondering how the reverse on it is supposed to work. Does anyone know how the reverse works on these? And i also am in need of parts, so if you have any please let me know. Thanks!!!
VinsRJ
You should have a a bronz reverse disc on your engine pulley which engages the veri drive when you pull the speed selector handle to its full rear-ward position.
You may have to make a couple adjustments to your adjuster rod in order to get it to work properly. I typically leave the reverse disc off because after the first time you hear the grinding noise you will never use it again, LOL!
