jay in nc 210 #1 Posted October 29, 2012 this week after work i leveled a large dirt pile & filled a low area in the back yard. i used the i beam drag to do the final leveling. so this morning i got out the 72 bronco 14 & hooked up the gang of aireators & punched holes then broadcast fescue seed & aireatored some more , hope it germinates . after that job was done i needed to tackle the leaf problem. i haven't had time to change over to the rear discharge decks so the 518 choped leaves & blew them into a row & i tried different tractors on one of the sweepers. first up was the c161 8 speed, it did well but the clevis hitch made it imposible to back up the sweeper. next upwas the 310-8 but it also has a sleve hitch so it has the same problem. so after dark i built a hitch extension so sweeper & cart pulling will be easy with this horse. last weekend i tried the commando 8 with reardischarge deck & it did wonderfull. but the best tractor for the sweeper is the commando 800 with big boy shoes. it's fast, turns quick & sips gas. i have the rear discharge deck that came with this tractor & after rebuilding it will be the perfect sweeper tractor. but with the high winds coming with huricane sandy i was fighting a loosing battle so next sunday i'll try again but most of the leaves will have fallen hopefully Jay 2 Share this post Link to post Share on other sites
Cole 25 #2 Posted October 29, 2012 I've been trying to clean up leaves all the way in kentucky and like you said, I can't compete with them either. :confusion-scratchheadblue: Share this post Link to post Share on other sites
farmer 1,081 #3 Posted October 29, 2012 :text-coolphotos: Looks like you've got your own 'tillage train' set up there. I have the same sweeper as you, it's amazing how much that hopper can hold, oh.. and I hope you put your leaves somewhere out of the wind. :P Share this post Link to post Share on other sites
Tankman 3,528 #4 Posted October 29, 2012 The read discharge deck and sweeper was the best combination. That sweeper can hold quite a bit and is difficult at times to dump the load. With 14 acres of woods directly behind me, I use my backpack blower almost daily. Extremely difficult trying to keep up with fallin' leaves. Overseed annually, fall is best. Works. Share this post Link to post Share on other sites
Don1977 605 #5 Posted October 29, 2012 Seeding and running the aireator over it should work great. That is what I use when planting grass. 1 Share this post Link to post Share on other sites
groundhog47 448 #6 Posted October 29, 2012 Seeding and running the aireator over it should work great. That is what I use when planting grass. Like the way you have the blocks held in place, looks like a very strong unit, did you make or is it a factory unit. The pillow block bearings ought to make it roll forever. Share this post Link to post Share on other sites
leeave96 496 #7 Posted October 29, 2012 Great looking machines you got and I really like to see pics of these Wheelhorse tractors at work. Don't know if you have a grader blade, but they are a lot of fun to use too. Good luck, Bill Share this post Link to post Share on other sites
Don1977 605 #8 Posted October 29, 2012 Seeding and running the aireator over it should work great. That is what I use when planting grass. Like the way you have the blocks held in place, looks like a very strong unit, did you make or is it a factory unit. The pillow block bearings ought to make it roll forever. I built it with some scrap angle and a piece of 6" pipe. I drilled the pipe for some 3/8" rod that I had and spot welded them in place. I have broke some off, I just hit it with the side grinder knock the rest inside and weld in another. 2 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #9 Posted October 30, 2012 Jay, we've been doing pretty much the same thing. I've been working at Mom's trying to get all the cleanup work done before Winter. I have a huge pile of leaves from her Maple trees that need to be burned. I blew them all down in a low spot in the front field in hopes the winds from Hurricane Sandy will not scatter them everywhere. I guess I will find out tomorrow how that went. I was so busy though I could not stop to take pics. Your place looks great! I know Jen thinks you are wonderful :wub: Share this post Link to post Share on other sites
