Lux Man 1 #1 Posted October 24, 2012 The timing push rod for the Kohler K301 according to the spec. is supposed to be 1.55" in length. At what length should they be replaced as they wear? I could not find the answer to that in the manual. Share this post Link to post Share on other sites
can whlvr 994 #2 Posted October 25, 2012 wouldnt it be when the tolerances for valve clearance can no longer be with in acceptable tollerances that are in the manual,sorry dont know them off hand Share this post Link to post Share on other sites
Lux Man 1 #3 Posted October 25, 2012 I'm sorry - the push rod that I am referring to is the one that operates the points. I think what you are referring to is the valve-to-tappet clearance. Share this post Link to post Share on other sites
rmaynard 16,836 #4 Posted October 25, 2012 My guess would be that you would need to change it if you can no longer set the correct points gap. Share this post Link to post Share on other sites
Buckshot 1 15 #5 Posted October 27, 2012 :) Points rod length: 7 and 8 HP K-series, Min: 1.250, Max: 1.260. 10 thru 16 HP, K-series. Min.1.500, Max: 1.600. O.D. both series Min: .184. All these numbers are from Brian Miller. web site. I do know that when I am working on a K-series with a alum. point rod, it is the 1st to go in the trash can. :flags-usa: Share this post Link to post Share on other sites
