stevasaurus 23,689 #26 Posted November 30, 2012 (edited) SUBURBANS & RJ 58/59 TRANSMISSION CROSS OVER CHART FOR WH #5003 and #5010 TRANSMISSIONS DESCRIPTION..............................................................WH #......................VENDOR..........QUANTITY...........SIZE BRONZE BEARING (AXLE)..........................................1503.......................CB-1618-12..........2..................1" X 1 1/8" X 1 1/2" BRONZE BEARING (DIFFERENTIAL HOUSING)..........1517.......................CB-2224-14..........2..................1 3/8" X 1 1/2" X 1 7/16" INPUT SHAFT & OUT END OF BRAKE SHAFT.............1519........................S8K ground..........4..................3/4" X 1 5/8" X 5/16" CLUSTER GEAR SHAFT & 11/44 GEAR BASE............1502........................NICE 412-35........3..................3/4" X 1 5/8" X 3/8" INPUT GEAR NEEDLE BEARING.................................1518........................B-108...................1..................5/8" X 15/16" X 1/2" BRONZE BEARINGS (CLUSTER GEAR SHAFT............1504.......................EP-1214-12..........2..................3/4" X 7/8" X 3/4" BRAKE SHAFT (NEEDLE) IF YOU HAVE THIS............1508.......................B-1212.................1..................3/4" X 1" X 3/4" SEALS AXLE (FROM TORO ONLY)..(CAP)...................1257.......................83-2840...............2 SEALS INPUT SHAFT & BRAKE SHAFT (BALL BRNG)..1234......................741643 timken......2 SEAL BRAKE SHAFT (IF NEEDLE BRNG).....................1303......................7410 skf................1 Edited November 30, 2012 by stevasaurus 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #27 Posted November 30, 2012 (edited) So Steve, what I gathered from that last video is this, regardless whether on not it's the early or later trans... before you open one up, you must confirm that you have a pair? Edited December 3, 2012 by TWENTYHORSETWIN 1 Share this post Link to post Share on other sites
stevasaurus 23,689 #28 Posted December 4, 2012 Here is a short video concerning the replacement differential that they sent out for the 5003 and 5010 transmissions. This particular differential has the bolt on bull gear to the differential housing and is talked about in the manual on page 12. click the video...easier to watch then to explain... Share this post Link to post Share on other sites
big mike 13 #29 Posted January 31, 2013 Steve,great videos! and.....DA BEARSSSSSSSS! Share this post Link to post Share on other sites
RJ 58 sc. 6 #30 Posted March 6, 2013 Thank you so much for the vids.RJ 58 sc. Share this post Link to post Share on other sites
HorseFixer 2,014 #31 Posted June 19, 2013 Another great video from Jurassic Park Productions. Really nice Steve. Great Video Steve! Bob made me spill my coffee. Share this post Link to post Share on other sites
RHODES 19 #32 Posted January 2, 2015 a good to know video.......thanks Share this post Link to post Share on other sites
