Foozerush 40 #1 Posted October 23, 2012 Sorta tossing the idea of getting a single stage blower, but wondering if you have to use the side wings on it? On the sidewalk beside my neighbor house there are bushes that run along the sidewalk and the right wing would rub into the bushes and I don't want the sticks/limbs getting into the auger. Does it impede the performance with one or both removed? Can't decide on what way I want to go with plow or blower, plow will be better in my case because of storage space in my garage, but might sacrifice space for a blower... But then I could use the blade to push dirt/rock in the summer time also... Then again I did see a video of a member throwing dirt with a blower.... Any insight to this question appreciated!! Share this post Link to post Share on other sites
rydogg 186 #2 Posted October 23, 2012 When I blow snow I take 1 wing off I was having problems with the wing pulling the front of the tractor when I was blowing deeper hard packed snow with the wing off I don't have the same problem it cuts much nicer. Share this post Link to post Share on other sites
littleredrider 409 #3 Posted October 23, 2012 I haven't tried without the wings, but like dogg said in the heavy stuff it will pull to one side or other. Maybe if some weight was added to the tractor it would help. This was on my lawn ranger, so already lite... Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted October 23, 2012 You can pull the wings no problem, it will only mean your cutting width will be smaller. Share this post Link to post Share on other sites
MalMac 1,333 #5 Posted October 23, 2012 What I have noticed with running with only one wing is not only will it pull to one side but I have seen wear on the side of the wing compared to the side with out the wing. Puts more pressure to the side with the wing thus more wear on the bearings and other parts. I saw this with a blower I repaired for a guy that did snow blowing for a private school where he had to remove one because of a curb. Share this post Link to post Share on other sites
Foozerush 40 #6 Posted October 24, 2012 Thanks for the replys... Guess I'll just go the plow route. Rydogg confirmed my thoughts that one wing would make tractor pull, MalMac thanks for sharing that bearing wear is a factor also.. Kelly I still want to road trip north to get some odd-n-end parts from you but I've been working 6 day weeks and wife and kids keep me busy... I'll PM you when I think I can excape Share this post Link to post Share on other sites
wallfish 18,450 #7 Posted October 24, 2012 With the blade on an angle it will also pull you. For $20 you can add #40 roller chain to the front tires and use what ever you want and you will stay on coarse 2 Share this post Link to post Share on other sites
chevrat68 19 #8 Posted October 25, 2012 That roller chain is a peach of an idea. I think I might try that this year. Thanks John! Share this post Link to post Share on other sites
Forest Road 594 #9 Posted October 25, 2012 I removed both wings from my single. I've seen a few singles that had broken welds from the stress or the wings. If you have 10.50"rear tires you'll need the wings. The roller chain works well! Share this post Link to post Share on other sites
pumper.atv 26 #10 Posted November 4, 2012 i run without the wings for three years now on the c121 and the only issue is the reduced cutting width Share this post Link to post Share on other sites
