Wishin4a416 2,191 #1 Posted October 20, 2012 I started on the 416 parts tractor today. I am going to change the seals in the rearend and paint and put it on the shelf or make a Winter project out of the tractor. Undecided as of now because I have no motor and 2 kids in school $$$$. As read here the hubs are either gallded on or loose. Well I was 50/50 so I took the loose hub off first and then used it to pull the other hub. I got that tip here. Thanks!!! Uhh, my hands are sore. I had to pull it a little at a time with the small bolts as I didnt have a socket big enough to put on the air gun for the 3/4 inch bolt that I used. But there off now and the axles cleaned up. One question tho, My right axle has a straight key and my left has a half moon key. Is this normal? Thanks again!!! My research here really helped from all the knowledge shared. Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted October 21, 2012 . One question tho, My right axle has a straight key and my left has a half moon key. Is this normal? I've only ever seen half moon (Woodruff) keys in axle shafts. What does the seat look like in the axle? Is it machined for a half-moon key? Share this post Link to post Share on other sites
Wishin4a416 2,191 #3 Posted October 21, 2012 . One question tho, My right axle has a straight key and my left has a half moon key. Is this normal? I've only ever seen half moon (Woodruff) keys in axle shafts. What does the seat look like in the axle? Is it machined for a half-moon key? No it is not. It is machined for a straight key. Odd aint it? Share this post Link to post Share on other sites
pfrederi 18,648 #4 Posted October 21, 2012 Look around the axle to see if it might have been repaired at one time by welding the old key way closed, turning it on a lathe to true it up, then cutting a new key way. The machine shop may have cut a straight keyway instead of a woodruff. Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted October 21, 2012 I've had a few axles here that had straight keys in them, not sure what tractor they were on right now, might have been on hydros, but the norm is woodruff keys. Share this post Link to post Share on other sites
Wishin4a416 2,191 #6 Posted October 21, 2012 Look around the axle to see if it might have been repaired at one time by welding the old key way closed, turning it on a lathe to true it up, then cutting a new key way. The machine shop may have cut a straight keyway instead of a woodruff. Your right. After closer inspection with my seeing glasses on, I can see the old outline of the factory key in the new keyway. Share this post Link to post Share on other sites
