JC 1965 1,532 #1 Posted October 18, 2012 I replaced the engine on my C81 with an old K 301. It runs great but i noticed that the amp gauge was always on the negative side even with the engine at full throtle. I checked the ac voltage on the two ac wires coming from the stator and was only getting 3 or 4 volts. So i pulled the flywheel and sure enough the stator was fried. I replaced the stator and now I'm getting 37 volts ac.and the amp guage is running on the pos. side and as i rev up the engine the amp guage goes even higher. Can I asume that i have the problem solved ? I don't know to check the regulator but since it's charging don't that mean the regulator is working properly ? Share this post Link to post Share on other sites
rmaynard 16,404 #2 Posted October 18, 2012 Check the voltage at the battery when the engine is running. It should be about 14.5 volts DC. Share this post Link to post Share on other sites
JC 1965 1,532 #3 Posted October 18, 2012 Bob, When i check the voltage accross the battery terminals i get 13.9 volts DC Share this post Link to post Share on other sites
Wheel-N-It 2,976 #4 Posted October 19, 2012 I think it is safe to assume you are in good shape now. Share this post Link to post Share on other sites
Save Old Iron 1,571 #5 Posted October 19, 2012 Now you have to think about why the stator fried in the first place. Old age? Excessive engine vibration? Possibly a near dead battery demanding a constant diet of high amperage eventually overheating the coil? Watch the ammeter. A battery in good condition will require only a short period of high amperage draw from the stator. The high positive indication should quickly TAPER OFF to a trickle within a few minutes. If you have minimal electrical accessories in use (and your battery is in good condition), the ammeter should be back down to near zero charge rate after a few minutes. Share this post Link to post Share on other sites
JC 1965 1,532 #6 Posted October 19, 2012 Wow chuck !! your just the person I think can help me out. First i don't know why the stator was bad, probably bad when I got the engine. I know this new stator is working properly. Now I'm questioning the condition of the Regulator/Rectifier. I checked the B+ terminal on the RR with the 2 AC stator wires connected and the engine off with the key in the on position, I'm getting the same voltage as I get across the battery terminals 12.6.DC. I assume that is ok. ( Forgot to mention the battery is new} Now here is my problem, With the engine running at 3600 RPM and the 2 AC stator wires connected, when I check the B+ terminal on the RR I get 22 Volts DC. From everything I've read it should be around 14.5 volts DC. Is that correct ? I've never had RR problems before. I have been searching The forum for info. but a lot of what I've read is confussing. Hope you can help me out. Thanks !! Share this post Link to post Share on other sites
rmaynard 16,404 #7 Posted October 19, 2012 Check to be sure that the R/R is properly grounded. An bad ground can produce voltages that are too high. Share this post Link to post Share on other sites
JC 1965 1,532 #8 Posted October 19, 2012 Bob, I cleaned the back of the RR and the surface that it mounts to. I also used star washers on the back side of the mounting surface. Would it help to run a jumper wire from the RR cooling fins to the tractor frame to make sure it is grounded ? Share this post Link to post Share on other sites
Save Old Iron 1,571 #9 Posted October 19, 2012 A quick jumper between the battery (-) terminal and the regulator case will tell if the RR needs replacement. If B+ doesn't drop to 14(ish) VDC, replace the RR. Share this post Link to post Share on other sites
rmaynard 16,404 #10 Posted October 19, 2012 What Chuck said is what I would recommend as well. Just be sure to clean the oxidation from the aluminum fin of the R/R case where you connect the jumper. Share this post Link to post Share on other sites
JC 1965 1,532 #11 Posted October 19, 2012 Thanks Chuck and Bob, I will hook up the jumper tomorrow. I will let you know the results. Thanks again !! :thumbs2: Share this post Link to post Share on other sites
JC 1965 1,532 #12 Posted October 20, 2012 Chuck and Bob, Today I cleaned one of the fins on the regulator and hooked up a jumper wire from the Battery neg. post to the fin on the RR that I cleaned. I checked the B+ terminal and got 19.5 volts DC. So I guess I need a new RR. Thanks for your help !! :thumbs2: 1 Share this post Link to post Share on other sites
rmaynard 16,404 #13 Posted October 20, 2012 You can get a R/R new from Milford Power for about $40.00. http://www.milfordpower.com/R10297-Voltage-Regulator-Replaces-Kohler-41-403-06-p/r10297.htm Good used ones can be found on eBay. Share this post Link to post Share on other sites
JC 1965 1,532 #14 Posted October 21, 2012 Boc , Thanks for the link to milford power. I'll check them out. Share this post Link to post Share on other sites
