snowhound 106 #1 Posted October 15, 2012 I wanted to check the valve settings on my Kohler M16 and was good about taking notes and photos as I disassembled it until I got to the reed valve I didn't take note of how the plate that holds the reed valve in was mounted. Does the high spot in the middle go against the reed valve or should the high spot be to the outside away from the reed valve? Ed (Snowhound) Share this post Link to post Share on other sites
gregg'shorses 77 #2 Posted October 16, 2012 http://www.kohlereng...a.pdf page 92 should refresh your memory. :canada: Share this post Link to post Share on other sites
Wheel-N-It 2,976 #3 Posted October 17, 2012 Ed, after you get the valves adjusted, be careful when snugging down the valve cover. If the "M" engines are like the "K" engines, you can warp the valve cover real easily. Then it will leak oil forever, or until you replace it with another cover (like I did). Van Share this post Link to post Share on other sites
snowhound 106 #4 Posted October 18, 2012 Thanks for the replies, I did take a look at the PDF at the Kohler site but the photo quality was poor so I really couldn't tell which way the part goes on. I guess I will have to try it the way that seems to be the most logical and hope for the best. Sweeping leaves and pine needles in W. Ma. Ed Share this post Link to post Share on other sites
tunahead72 2,551 #5 Posted October 19, 2012 (edited) Ed, The guy who rebuilt my K241 a few years ago reassembled the breather in "the way that seemed to be the most logical" to him at the time, and got it absolutely WRONG. Just a friendly suggestion -- do yourself a favor, and get it right the first time so you don't have to pull it back apart and do it again too soon. I would try to find a parts manual for the Magnum on the Kohler site, or look at the parts diagrams on some of the online parts supplier web sites. Or try a search on "crankcase breather" on RedSquare. Or wait for somebody who has a photo or diagram handy for exactly that model. I'll post a link in a few minutes to a thread I started a while ago on my own breather assembly, maybe the set up is close enough for you to make an educated guess at how yours is supposed to go back together. Later... Another Ed EDIT: Here's the thread I was thinking about, there's a nice diagram in the second post, maybe yours is similar: Edited October 19, 2012 by tunahead72 Share this post Link to post Share on other sites
snowhound 106 #6 Posted October 20, 2012 Thanks Ed I went to Parts Tree and found a diagram, have it back together but still having what seems to be a compression release issue. I did see a recent post about checking the voltage draw of the starter I'll give that a try. Ed Share this post Link to post Share on other sites
Cole 25 #7 Posted October 22, 2012 Yep, thats the thing i screw up the most when reassembling engines is the breather, I printed the page out of the service manual about a year ago and hung it above my work bench along with specs, makes the whole process alot easier. Share this post Link to post Share on other sites
snowhound 106 #8 Posted October 22, 2012 I also printed the diagram for the breather so I don't make the same mistake twice, I checked the voltage draw and it is fine so it looks like I need to go back in, I did find a thread about small balls of plastic in the valve area and some very small ones getting into the compression release keeping it from operating correctly. I did find some plastic when I check the valves so I guess my next step will be to look much closer at the compression release. Again thanks for all the replies Ed Share this post Link to post Share on other sites
MalMac 1,332 #9 Posted October 23, 2012 Make sure the oil sensor has not come apart and disintegrated. Just helped a friend rebuild his and found that the sensor float and totally disintegrated and pieces were all over in the engine. There were alot of them jammed up around the ACR and the springs. This was on a Mag 16. Share this post Link to post Share on other sites
snowhound 106 #10 Posted October 24, 2012 At this point I feel that is the problem, I did find some plastic when I checked the valves. Share this post Link to post Share on other sites
