rgodw4
PTO switch on a 265h keeps melting
rgodw4
the pto switch on my toro wheel horse went out so I replaced it and it melted again, why and what would cause this to draw to many amps?
Save Old Iron
is it the main body of the switch or the area around the terminals that melts?
melting = heat
heat = energy consumed
energy consumed = resistance
resistance = corrosion / oxidation
check for corrosion within the terminals of the wires going to the PTO switch. Are any wires going to the PTO switch crispy or discolored?
You may also want to crack open the burned switch to see if the contacts are melted or possibly vaporized / carbonized. Their condition will give additional clues.
rgodw4
The main body of the pto switch melted.
SousaKerry
It could be that the PTO itself is drawing too much amperage due to a short, but I would think that you would blow a fuse first. I would ensure the condition of all the wiring leading up to the PTO from the switch and check that the fuse has the proper rating and has not been bypassed. If you have an electrical meter and can check the resistance of the PTO that would eliminate a dead short in the coil.
Save Old Iron
how long did it take for the new switch to melt? seconds? hours? days?
