rgodw4 0 #1 Posted October 15, 2012 the pto switch on my toro wheel horse went out so I replaced it and it melted again, why and what would cause this to draw to many amps? Share this post Link to post Share on other sites
Save Old Iron 1,571 #2 Posted October 15, 2012 is it the main body of the switch or the area around the terminals that melts? melting = heat heat = energy consumed energy consumed = resistance resistance = corrosion / oxidation check for corrosion within the terminals of the wires going to the PTO switch. Are any wires going to the PTO switch crispy or discolored? You may also want to crack open the burned switch to see if the contacts are melted or possibly vaporized / carbonized. Their condition will give additional clues. Share this post Link to post Share on other sites
rgodw4 0 #3 Posted October 15, 2012 The main body of the pto switch melted. Share this post Link to post Share on other sites
SousaKerry 502 #4 Posted October 15, 2012 It could be that the PTO itself is drawing too much amperage due to a short, but I would think that you would blow a fuse first. I would ensure the condition of all the wiring leading up to the PTO from the switch and check that the fuse has the proper rating and has not been bypassed. If you have an electrical meter and can check the resistance of the PTO that would eliminate a dead short in the coil. Share this post Link to post Share on other sites
Save Old Iron 1,571 #5 Posted October 15, 2012 how long did it take for the new switch to melt? seconds? hours? days? Share this post Link to post Share on other sites
