Flatheadpuller 6 #1 Posted October 10, 2012 Although not red. I though you guys would like it. 45cid Kohler Command. Roller motor. VM11 rear tires. Cub drive train. My ole mans ride. I build his engines. 2 Share this post Link to post Share on other sites
Jeremy Watson 22 #2 Posted October 10, 2012 That is bad a$$! Was that in Grandville somewhere? I'm close by in Hudsonville. Jeremy Share this post Link to post Share on other sites
Flatheadpuller 6 #3 Posted October 10, 2012 Cedar springs michigan during Red Flannel last weekend. Share this post Link to post Share on other sites
JackC 617 #4 Posted October 11, 2012 Sounds powerful. What were the mods to the engine? Can a roller motor be built and still be tame enough for yard duty? Share this post Link to post Share on other sites
AMC RULES 37,196 #5 Posted October 11, 2012 Just sounds Bada$$...that's all. Share this post Link to post Share on other sites
Flatheadpuller 6 #7 Posted October 11, 2012 You could make a roller motor that wasnt so abnoxious as this one. I have seen some 4500rpm roller motors. I really dont see a reason to have a roller motor in a mower or everday use engine. The flat tappet stuff is just fine. This one has billet rods, je flattops, billet steel roller cam from vogel, comp lifters, comp springs for a SBC. SBC pro mag roller rockers, Highly reworked stock heads. 12.5-1 compression. 1.200 gas carb from MWSC. Reworked stock 2 bbl intake. Crank trigger ign. 30lbs flywheel. MWSC 4 puck clutch, dart carrier and axles, 2 gear pulling setup with a hardened top shaft and gears from vogel. This winters updates are a R-1 gear change. Share this post Link to post Share on other sites
JackC 617 #8 Posted October 14, 2012 Sounds expensive. Don't think I could afford all that unless I had a son that built engines. Share this post Link to post Share on other sites
