k29349 1 #1 Posted October 7, 2012 Can anyone tell me what mods would have to be made to put a Tiller model # 67-36TL01 (1976 model I think?) on a 1993 416-8? Share this post Link to post Share on other sites
kpinnc 15,766 #2 Posted October 8, 2012 I'm assuming you only have the tiller, so here is a pic from the Toro MPV. Pics always seem to make things easier... You'll need part #78, the rear hitch- with everything shown with it. You'll need part #88, the front pulley rockshaft, with the pulleys. And you'll need part #66, the lift rockshaft with all the cables. I did not list part numbers because there are more than one that will work on some of this. Most everything on the list shows up on Ebay pretty regularly, though it can be expensive. Some parts may be available from Toro, but they are higher than what you can buy them used for. Good luck! A tiller is a very useful implement, and they are very rugged. Share this post Link to post Share on other sites
k29349 1 #3 Posted October 8, 2012 Thank you for your response.. The tiller has all the parts except #66. I just did'nt know if those 1976 parts were going to fit my 1993 416-8 Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted October 8, 2012 The tiller will be a direct fit with the axle bracket and idler pulleys, the rockshaft and cable will not work from a 76 tractor you will need one from a 78 or newer, and the tube and front clevis for a 8 speed, if you want or need the rock shaft set up I'm pretty sure I have a complete one that will fit your tractor, send me a PM. Share this post Link to post Share on other sites
