Raider12 13 #1 Posted July 24, 2008 I have heard that it may be possible to take my old Raidar 12 and add the newer steering system off of a 520 with the gear reduction? Is this possible? How much work involved? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted July 24, 2008 It's very possible, but probably not necessary. (unless you install a front end loader) If the current steering parts are in good condition and well lubed, it should steer fine. A quicker (and cheaper) way to reduce the steering effort would be to install a larger steering wheel. If you use you Raider to mow grass around many obstacles, you probably won't like the reduction set-up. Share this post Link to post Share on other sites
Raider12 13 #3 Posted July 24, 2008 Sound like good advise. Thanks for your input. I will leave it alone! Share this post Link to post Share on other sites
