dsholler 54 #1 Posted October 6, 2012 There are some weights on ebay that claim to be off a 1054. I have never seen a 1054. I am I correct in assuming that it has standard 12 inch wheels, and I should be able to put these weights on my 414? Share this post Link to post Share on other sites
Vinylguy 4,747 #2 Posted October 6, 2012 The 1054 has much larger rear wheels. Someone who knows will let you know soon but i would not think they could work Share this post Link to post Share on other sites
dw753 215 #3 Posted October 6, 2012 those are Red E tractor weights not wheel horse weights Share this post Link to post Share on other sites
dsholler 54 #4 Posted October 6, 2012 I can see the Red E on them. But I am not a purist, and they appear to be a decent deal for cast 50lb weights. I just wondered if anyone knew off the top of their head if they would fit. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #5 Posted October 6, 2012 1054 has 15 inch wheels and they should be a 4 lug rim if I am correct. Share this post Link to post Share on other sites
horsesaver98 18 #6 Posted October 6, 2012 they are 4 lug and thay do not go on the front of the rim they go on the back side so they will not fit Share this post Link to post Share on other sites
travlindave 18 #7 Posted October 7, 2012 The WW-93 Wheel Weights are made in two 45 pound halves that bolt from the inside of the 15 inch wheel . As others have indicated, the wheel has four holes for lug nutes from the outside. On the 1054 when placing wheel weights on you need to use extended bolts from the inside to the wheel to the outside and use an older GM type lug nut We have two sets of these and they are heavy weights to add to the rear of the 1054. They will also fit the GT 14 but I am unaware of any other Wheel Horse that they wheels that they will securly bolt on. Share this post Link to post Share on other sites
dsholler 54 #8 Posted October 7, 2012 Thanks guys. They obviously do not fit. I will have to continue my search for some cast weights, or give in and just get some concrete filled ones. p.s. anyone got a line on where to shop for decent chains? Share this post Link to post Share on other sites
dw753 215 #9 Posted October 7, 2012 I have a Heavy set of cast ones id sell for 150 plus shipping. Probably be around 30 bucks in large flat rate boxes they are heavy. Hit up Racinfool i think he had set of nice chains for sale Share this post Link to post Share on other sites
Tankman 3,528 #10 Posted October 7, 2012 Try makin' some weights! These two came with a Horse I picked up recently. Cast brake drums, two bolts tacked in, filled with concrete. The brake drums (size ?) fit the wheels perfectly. I am guessin', "Maybe I could find drums to fit any wheel?" Share this post Link to post Share on other sites
Kelly 1,037 #11 Posted October 7, 2012 I have two pallets of weights, many cast iron ones, most I can ship in 2 flat rate boxes for $30 send me a PM, but I will say the cast weights are not cheap. Share this post Link to post Share on other sites
