AmalgamousProxy 2 #1 Posted October 6, 2012 I came across a few tractors originally equipped with a governor that had the governor bypassed with straight throttle linkage to the carburetor. I've had tractors that had full straight throttle. Personally I kinda like governor throttle on my tractor, you know, that surge you get when you hit an incline or load. Not to mention it's easier on the engine. What's your opinions? Share this post Link to post Share on other sites
MarkPalmer 81 #2 Posted October 6, 2012 Small air cooled engines used on power equipment should always use the governor if so equipped. They are mechanically designed for a top RPM, (usually between 3500-4000 RPM), and as you mention they will keep the engine speed steady under varying loads. Many people bypass engine governors for various reasons- the springs break and they are too cheap to replace them, they can't figure out how to adjust the governor linkages and don't want to read a manual, they think bypassing it will get them more power (it will, at the great expense of engine life), or they replace governor linkages or carbs with different parts and end up with a mess that can't adjust. There used to be this old dirty idiot who lived behind my parents house who had a pile of a governor-less Cub 108 he would attempt to mow with. He would start this thing up to a cloud of oil smoke, and it would wind up to about 6000 RPM. He would then fire up the mower to the nice sound of grinding spindle bearings and belt smoke. Every time he hit one patch of grass the engine would slow to just about a stall, backfire loudly through the exhaust, then he would stop and let it wind up again and keep repeating the process. It was annoying and amusing to watch all at the same time -Mark- 3 Share this post Link to post Share on other sites
AmalgamousProxy 2 #3 Posted October 6, 2012 I think the vast majority do so for the power boost then complain that (insert engine brand name here) is garbage because it blew up after a season or two. Ignorance isn't always bliss... 1 Share this post Link to post Share on other sites
can whlvr 994 #4 Posted October 7, 2012 we used to do this one our go carts so they would go faster,but ya it was very hard on them,and we blew up a couple of good old kohlers doing this 1 Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted October 7, 2012 Governors are their for the same reason there is a rev limiter in your car. Rotating assemblies are only balanced for a certain RPM any faster and they fly apart. Share this post Link to post Share on other sites
krazy_horse 59 #6 Posted October 7, 2012 My thinking is the Kohler engineers knew a whole lot more about these engines than I do, I try to go by the book on service and settings on them. Knock on wood but I've got good service out of all but one which was a two cylinder D model back in the 70's 1 Share this post Link to post Share on other sites
markjs 2 #7 Posted October 14, 2012 There used to be this old dirty idiot who lived behind my parents house who had a pile of a governor-less Cub 108 he would attempt to mow with. He would start this thing up to a cloud of oil smoke, and it would wind up to about 6000 RPM. He would then fire up the mower to the nice sound of grinding spindle bearings and belt smoke. Every time he hit one patch of grass the engine would slow to just about a stall, backfire loudly through the exhaust, then he would stop and let it wind up again and keep repeating the process. It was annoying and amusing to watch all at the same time :ROTF: :ROTF: Share this post Link to post Share on other sites
bowtiebutler956 650 #8 Posted October 14, 2012 I remove the governors on all my off road buggies, but definitely not my Garden Tractors! The buggies are hot rodded toys that we try to get every last drop of speed out of, and to date I have'nt had one explode yet, but there's always tomorrow! Matt :flags-texas: Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted October 14, 2012 When I was living in Indiana, the local Toro dealer was around in the days of the Indy 2 1/2 mile race. He told me that they all tied a piece of string to the governor arm so they could pull on it from the seat. Wonder if all those old roundhoods blew up earlier than they should have after that sort of treatment. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,287 #10 Posted October 14, 2012 OK, since the subject has been brought up,....where would I find some helpful info on adjusting the governor on my techy H60's and HH60? bought a few manuals on ebay and the subject is brought-up , but not the process or/and the precedures are not explained . I've "tinkered" with them some but not happy with the results. For instance,(i.e.) my L-157 lawn ranger runs fine and the governor works but it's almost like it holds the RPM's back too much. so any adjustments I would try to do have negitive effects like too high of rpms or engine bogs down on hills. any comment welcome . Share this post Link to post Share on other sites
roscoemi 245 #11 Posted October 17, 2012 There is a link somewhere on this site that shows how to adjust the gov on about any small engine that is super simple, but for the life of me I can't find it . Try a search. Share this post Link to post Share on other sites
