jeremi3210 744 #1 Posted October 3, 2012 Any know off hand what size belt fits a 1054 starter gen? Share this post Link to post Share on other sites
diesel cowboy 263 #2 Posted October 3, 2012 The belt I found that fits best on mine is a gates 7345. Its 13/32"X35-1/8". Hope this helps. Stewart Share this post Link to post Share on other sites
HorseWhisperer 243 #3 Posted October 3, 2012 (edited) 3/8 by 34 Its tight but not too tight once on. Edited October 3, 2012 by commandomayo Share this post Link to post Share on other sites
Martin 2,134 #4 Posted October 3, 2012 ive found that size is too big. the terminals on the regulator hit the battery..... the original belt was #1593 which is a 3/8" x 34.4" most of the aftermarket belts are either shorter or longer i used a napa 3L340W on my 1054, its a little difficult to get it on there, but once you do and adjust the belt tension the s/g sits just about right..... theres adjustment room either way and still room between the terminals and battery.... Share this post Link to post Share on other sites
855ownerJoel 32 #5 Posted October 25, 2012 Martin, Do you have or could you send me a close up photo of the belt pulley on the engine (PTO as I see many call it)? I need to look at mine, for proper restore. I think mine is wrong since its a double pulley and i believe it should be a triple. Thanks Share this post Link to post Share on other sites
Martin 2,134 #6 Posted October 25, 2012 this one? this is the correct one, a double..... outside groove trans drive belt, inside groove hydro pump drive belt. the pto drive pulley fits on the end of the output shaft and is not shown in these two pics....... looks like this one on my 1057...... 1 Share this post Link to post Share on other sites
