welderman85 53 #1 Posted September 29, 2012 :eusa-think: after a quick mow this morning i was going to give the 314h a oil change and a new air filter pluse a little cleaning. i went to tsc and got all the stuff came back and went to work when i pulled off the air cleaner i noticed it was thicker then the one i had just bought. so i looked at the package and its says it will fit a 14hp magnum. so i went on parts tree to check part numbers and they say the correct one is no longer. anyone else have this issue or am i just shopping in the wong place. thanks Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted September 29, 2012 You can go to Wix Filters website and look up some numbers. http://www.wixfilters.com/Lookup/Applications.aspx?Section=4 They actually list 3 different filters for a Magnum 14. You can get Wix filters from Napa. Share this post Link to post Share on other sites
can whlvr 994 #3 Posted September 29, 2012 i buy stens,my local rental shop gets them for me Share this post Link to post Share on other sites
welderman85 53 #4 Posted September 30, 2012 thank you i just looked up the wix and found what i needed. do they come with new pre filters. thanks again Share this post Link to post Share on other sites
