Butch 194 #1 Posted September 25, 2012 The drive belt is spinning the transmission fan so power is making it to the transmission. The hubs are on tight. I've read from time to time about using the right filter. I put on a Baldwin filter last fall which crossed checked with the Toro filter. Could this be a problem? The oil is fine. Maybe 20 hours on it. Pressure does build up because I put my wife on the rear hitch and it raised and lowered her with no problem. The last few times I used the tractor it did have problems moving. After I pushed it a few feet it would work. It did get a good workout for several hours using the moldboard plow. Any ideas? Thanks. Share this post Link to post Share on other sites
Butch 194 #2 Posted September 25, 2012 Went back out and tried the tractor again just for the heck of it and it took right off! I'm baffled. Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted September 25, 2012 Sounds like a sticking valve, is this a Eaton or a sunstrand? Share this post Link to post Share on other sites
Butch 194 #4 Posted September 26, 2012 Sounds like a sticking valve, is this a Eaton or a sunstrand? Don't know. How do you tell the difference? The tractor doesn't have any identifying plates anywhere. Share this post Link to post Share on other sites
pfrederi 19,940 #5 Posted September 26, 2012 oil filter faces rear Eaton, faces right side Sundstrand Share this post Link to post Share on other sites
SousaKerry 503 #6 Posted September 26, 2012 C-175 should almost all have Eatons The only Sundstrands on Blackhoods were early 1980. Halfway through the year they changed to Eaton, probably when the Sundstrands ran out. What is the model number of the tractor should be something like 01-17KE01 for 1980-1981, 01-17KE02 1982 and so on 1 Share this post Link to post Share on other sites
Butch 194 #7 Posted September 26, 2012 Thanks guys. It's an Eaton. Share this post Link to post Share on other sites
rwilson 128 #8 Posted September 27, 2012 I would check the keyway in the input shaft behind the fan. could have sheard a key?? Share this post Link to post Share on other sites
SousaKerry 503 #9 Posted September 28, 2012 It could be an internal problem between the motor drive gear and the differential but I would eliminate everything else before pulling the tranny and popping off the side cover to check it. There is a fairly good repair manual for the Eaton Transmission available with a lot of very useful info. It is available in the Yahoo manual groups have to do some searching I am not sure which one Share this post Link to post Share on other sites
Butch 194 #10 Posted October 27, 2012 The other day I started the tractor up and went to take off and nothing. The mower deck was in the down position. For some reason I raised the deck and the tractor took off!! Could it be something to do with the hydraulics? Share this post Link to post Share on other sites
can whlvr 994 #11 Posted October 27, 2012 the eatons do take some time before they will move,this is more true when it gets cold out,and some take a few minutes to warm up,but if it gives trouble when warm something else is wrong Share this post Link to post Share on other sites
Sparky-(Admin) 24,658 #12 Posted October 27, 2012 I've read from time to time about using the right filter. I put on a Baldwin filter last fall which crossed checked with the Toro filter. Could this be a problem? The oil is fine. Maybe 20 hours on it. The last few times I used the tractor it did have problems moving. After I pushed it a few feet it would work. Was this tractor operating just fine before this Baldwin filter?? I would invest in a genuine TORO filter and do a filter swap, top up the fluid and see what you have. Mike........ Share this post Link to post Share on other sites
