Jake Kuhn 1,600 #1 Posted September 21, 2012 Hi guys, Well I now have two hydro's and both of them leak oil...VERY BAD! If you let them sit over night they will leak almost all of it out. They are on a early 70's charger 10 and a 875. I'll get some pics of the trans up this weekend. Just wondered if anyone has had these issues before? Just curious if its a simple fix. Or do I need to tear the whole trans apart? Thanks, Jake Share this post Link to post Share on other sites
AMC RULES 37,260 #2 Posted September 22, 2012 Sounds pretty bad, where are they leaking from Jake? Share this post Link to post Share on other sites
pfrederi 21,216 #3 Posted September 22, 2012 #1 Is this a sudden onset #2 where is it leaking from, Axle seal, drain plug, housing gasket, hydromotor to transaxle gasket? # 3 do they have lift cylinders I have several hydros but none suddenly started leaking as badly as you describe. Share this post Link to post Share on other sites
Callen 64 #4 Posted September 23, 2012 I had a Charger 12 that leaked like that. The O-rings on the dc shaft was brittle. You could fill it and run all day wouldn't leak till it set for awhile. Is there oil in the bottom of the dash tower? Share this post Link to post Share on other sites
Trouty56 568 #5 Posted September 23, 2012 Have you checked to be sure there is a drain plug???? Sorry...bad joke.... 1 Share this post Link to post Share on other sites
AMC RULES 37,260 #6 Posted September 23, 2012 Have you checked to be sure there is a drain plug???? Sorry...bad joke.... :ROTF: Share this post Link to post Share on other sites
