krazy_horse 59 #1 Posted September 18, 2012 I need the part number for a Kohler 181 Breather gasket. I think the 8 horse takes two gaskets. Also please tell me where I can find engine parts numbers.I down loaded the service manual but no part #s given. Thanks as always, Jim Share this post Link to post Share on other sites
groundhog47 448 #2 Posted September 18, 2012 Hey Jim, What did that engine come off. Not familiar with all the K#s, but numbers may be in my parts book. Catch yo later Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted September 18, 2012 http://www.partstree.com/parts/?lc=kohler_engines&mn=K181-30108+WHEEL+HORSE+%288+HP+%286+kW%29+SPECS+30100-30848%29&dn=catalogs_17189 Share this post Link to post Share on other sites
groundhog47 448 #4 Posted September 18, 2012 Jim, am not endorsing this site but has some part info I use to look around and they list nearly the K181...s http://www.partstree.com/parts/?lc=kohler_engines&mn=K181&gclid=CPXAiJ7zvbICFQTOnAodFWIAyg Just click on your specific spec and look at that sect. Good huntin' Share this post Link to post Share on other sites
groundhog47 448 #5 Posted September 18, 2012 Jim Found one for WH K181 one hole at top 1 hole l & r >>> 9 Diagram: K181-30584+WHEEL+HORSE+%288+HP+%286+kW%29+SPECS+30100-30848%29 Air Intake 1-2-68 TP-2045-B KOH Kohler Engines 41-041-11-S GASKET Believe it was on page 24 but all specs seem to have at least 3 air intake types. Gerry Share this post Link to post Share on other sites
krazy_horse 59 #6 Posted September 18, 2012 Thanks Guys, It is # 230048 and I do need two.Thanks everybody Share this post Link to post Share on other sites
groundhog47 448 #7 Posted September 19, 2012 Woops, thought you meant air "breather" rather than crancase. That # does correspond to my IPB listing. Good Day, Gerry Share this post Link to post Share on other sites
MarkPalmer 81 #8 Posted September 20, 2012 The breather gaskets are simple ones you can cut from a roll of gasket material that will cost you about the same as what places charge just for those two gaskets. Just use the breather plate as a template and cut around the gasket sheet with an X-Acto knife, then cut the center out to make a 1/8" wide rectangular gasket- make 2 and tack them in place with RTV. Make sure the drain back hole in breather plate is not covered with gasket. The middle sections of the gasket that go through the stud don't do a thing as far as a gasket goes, so you don't need to bother with that as part of them. -Mark- 1 Share this post Link to post Share on other sites
