Will G
10 hp Teccy no spark
Will G
Not on a Horse but I need some help. I'm helping a buddy of mine get his Sears ST/10 running and the 10 hp cast iron Teccy has no spark. The numbers on the shroud are 143 659012 serial number 5003E. The shroud also states it has solid state ign. so am I correct in guessing it has no points?
KATO
You are correct . it does not have points . It has a module under the flywheel shroud.Part numbers 610906 or 610748 or 610855.
There is a member here that is an electrical GURU. (save old iron). I have also refered to this site for info.
there are several links at the top of the home page in small print with a ton of good stuff.
http://home.earthlink.net/~edstoller/index.html
KEN
Will G
Did some testing today on it and found that the ssi module is dead.
woodchuckfarmer
Check out Brian Millers web site
Will G
Do you have a link?
Kelly
I have a couple ign. module here off engines that broke rods so they were running when they died, send me a PM if you need one.
Will G
Thanks Kelly, will PM you if I need one.
