Will G 3 #1 Posted September 16, 2012 Not on a Horse but I need some help. I'm helping a buddy of mine get his Sears ST/10 running and the 10 hp cast iron Teccy has no spark. The numbers on the shroud are 143 659012 serial number 5003E. The shroud also states it has solid state ign. so am I correct in guessing it has no points? Share this post Link to post Share on other sites
KATO 115 #2 Posted September 16, 2012 You are correct . it does not have points . It has a module under the flywheel shroud.Part numbers 610906 or 610748 or 610855. There is a member here that is an electrical GURU. (save old iron). I have also refered to this site for info. there are several links at the top of the home page in small print with a ton of good stuff. http://home.earthlink.net/~edstoller/index.html KEN Share this post Link to post Share on other sites
Will G 3 #3 Posted September 16, 2012 Did some testing today on it and found that the ssi module is dead. Share this post Link to post Share on other sites
woodchuckfarmer 333 #4 Posted September 17, 2012 Check out Brian Millers web site Share this post Link to post Share on other sites
Will G 3 #5 Posted September 17, 2012 Do you have a link? Share this post Link to post Share on other sites
Kelly 1,037 #6 Posted September 17, 2012 I have a couple ign. module here off engines that broke rods so they were running when they died, send me a PM if you need one. Share this post Link to post Share on other sites
Will G 3 #7 Posted September 17, 2012 Thanks Kelly, will PM you if I need one. Share this post Link to post Share on other sites
