handyman 1 #1 Posted July 22, 2008 While trying to remove the wheel hub on my Charger 10, I had a gear puller on it and was having no luck. I gave it a couple of good smacks with a hammer and low and behold, the axle shaft slid out. Is there a clip on the end that is supposed to hold the shaft in? I am guessing that I have to split the case now to fix? Any thoughts or suggestions. I hate learning not to do things the hard way. Share this post Link to post Share on other sites
Raider12 14 #2 Posted July 22, 2008 Yes, you are correct! You will have to split the case and open the differential in order to get the axle back on place then reinstall the snap ring. I have have "been there... done that" And it sucks too. I made a custom puller just to pull off my hubs. Share this post Link to post Share on other sites
HorseFixer 2,014 #3 Posted July 22, 2008 I hate learning not to do things the hard way. Bro sometimes when ya do things the hard way ya learn more! The school of hard knocks is where I graduated from! TOP OF MY CLASS Hang in there It's a learning experience! Duke Share this post Link to post Share on other sites
proshop 0 #4 Posted July 22, 2008 I had to do the same thing. the kepper slid off the shaft and rounded the edges off the end. I would take a thin file and sharpen up the groove before you put the clip back on. mine was on the left side. Share this post Link to post Share on other sites
handyman 1 #5 Posted July 25, 2008 Radair12, I would like to see your puller that you made up yanking the hubs off. Thanks. Share this post Link to post Share on other sites
Curmudgeon 28 #6 Posted July 27, 2008 Here's what I made: Your's may be different...... Share this post Link to post Share on other sites
linen beige 16 #7 Posted July 27, 2008 I have a large bearing seperator from harbor Freight that a puller can be screwed to. It puts pressure on the inner circumference of the "axle tube" portion of the hubs right up against the axle, rather than out on the flange. You didn't say if you got the hub off the axle. If not, then while the axle is out you should use a good shop press to remove the hub so it won't be stuck if you have to take it off again after this repair. Share this post Link to post Share on other sites
Raider12 14 #8 Posted August 14, 2008 Radair12, I would like to see your puller that you made up yanking the hubs off. Thanks. Im sorry I didn't post this picture earlier. Her is a pic of the pull for the hubs that I had made. Share this post Link to post Share on other sites
