608KEB 808 #1 Posted September 13, 2012 I am trying to free up the steering wheel/ roll pin and the hydro shaft/ lever on a B-100 I'm restoring. I got the inner shaft of the hydro lever apart with no problems on a different B-100. But this one is stuck. It doesn't look rusted. But it must be. I tried tapping the shaft out but no luck. Can I heat the Hydro shaft? To free the steering wheel I've set the tower upright, took the steering cap off and filled it up with PB blaster. I can't heat the shaft, because I'll damage the steering wheel. I've heard of using a 50/50 mix of Acetone/ATF will this damage the rubber steering wheel? I have heard of using Kroil penetrating oil. Has anbody tried this. If so, where can I purchase it? Share this post Link to post Share on other sites
dcrage 631 #2 Posted September 13, 2012 I tried the 50/50 acetone/ATF on my mule drive and it didn't work very well -- My biggest complaint was that is was NOT miscible (they don't mix together at that ratio) -- There was a whole lot of ATF that never went into the acetone Share this post Link to post Share on other sites
Rooster 192 #3 Posted September 13, 2012 I have found the best for freeing rusted parts is e-tanks. For. Something like a steering wheel alot of times I will make a temporary use tank. I have even used a cardboard box with a trash bag. Few hours of bubbling and the parts are freed up, no damage!! 1 Share this post Link to post Share on other sites
roost 1 #4 Posted September 13, 2012 the 50/50 acetone atf works well on rusted parts, but i found that if you have it in a spray bottle is to shake it up before use. the trick for steering wheels is to be able to keep it on the shaft. i think it has a half moon key on there also? Share this post Link to post Share on other sites
608KEB 808 #5 Posted September 13, 2012 Will the acetone or E-tank methods damage the steering wheel? Thanks. KB Share this post Link to post Share on other sites
dcrage 631 #6 Posted September 13, 2012 The acetone might although I wouldn't expect it to -- The only way to know for sure is to try it -- Put a drop or two of acetone on the wheel and see what happens -- Acetone isn't that strong of an organic solvent, so again I wouldn't expect a problem Share this post Link to post Share on other sites
prondzy 3,889 #7 Posted September 13, 2012 There is a penetrating lubricant called Kroil it is an industrial strength lube and can only be bought online there is none in stores. Seen it on the TV show Stacy Davids gears and the guys at work swear by it (factory mechanics) just soak it down wait a couple days and then try should come out easy. I haven't purchased yet but plan on it real soon. Share this post Link to post Share on other sites
gomer gump 8 #8 Posted September 14, 2012 had one on an old electro 12 let it soak in pb blaster for a few days it came right out tried it again on another old tractor it was rusted solid couldn,t get it out so heated it off with a torch an bought a different steering wheel had a two stage wh horse snowthrower couldn,t get the auger and shaft seperated tried everything imaginable could not get it so just bought a new one sometimes parts get too rusted an its like their welded together from the rust just buy new or used in good shape an when you put new or used pts on coat them with some sort of lube usually i use a lot of white grease cheap an seems to work real good i worked at an old uniroyal plant in indiana when i was a kid an ran a machine we used a chemical called m.e.k. methyl ethyl keytone it,s extremely flamable but i swear it would free up anything rusted or stuck but probably eat up rubber or plastic . i don,t think you can even buy it but maybe don,t know. goood luck Share this post Link to post Share on other sites
kthack657 328 #9 Posted September 14, 2012 Heat can also work to free parts, a small torch should do the trick Share this post Link to post Share on other sites
Road-Track 39 #10 Posted September 14, 2012 m.e.k. methyl ethyl keytone is the industrial name for Acetone. It has a flash point close to gasoline so watch out. PB Blaster, heat or an e-tank are the safest. Share this post Link to post Share on other sites
kpinnc 15,823 #11 Posted September 14, 2012 m.e.k. methyl ethyl keytone We used to call the stuff Methyl Ethyl Death in the military, because it's really bad stuff. Flammability is not the issue- it's bad on your skin, will blind you if it gets in your eyes, and the vapors alone can kill you. If you use it, please do so carefully. To answer the original question: Nothing frees up rusted parts like an E-Tank. It won't hurt the steering wheel UNLESS there is significant rust under the plastic itself. The plastic parts could "loosen" a bit from the material underneath them being removed by the process, but only if they are VERY rusty. Otherwise, the process does no harm to plastic. Just keep all non-ferrous metals (aluminum, brass, copper, zinc-coatings, etc) out of the solution. Copper makes a green sludge, galvanized makes an orange one. Aluminum will be dissolved completely. Stainless steel adds by-products to the solution which are extremely toxic. Never put anything in the solution other than regular steel or cast iron. Good luck! Share this post Link to post Share on other sites
dcrage 631 #12 Posted September 14, 2012 The chemist in me talking here -- I want to make it very clear to everyone that methyl ethyl ketone and acetone are NOT the same compound -- They would be close to each other (acetone could be called methyl methyl ketone) but that small difference could have significant differences in physical properties -- We all have had experience with acetone; it is a real common household solvent (i.e. fingernail polish remover) -- MEK has a slightly higer boiling point and is a stronger solvent (think it will penetrate your skin faster than acetone) -- Acetone is totally water soluble where as MEK has limited water solubility (although it is a significant amount) -- All in all I would be a little bit more leary of MEK than I would be of acetone BOTH WILL GO BOOM really quickly around an ignition source!!!! 1 Share this post Link to post Share on other sites
608KEB 808 #13 Posted September 22, 2012 Thanks for the suggestions, I'm going to givr the e-tank a try. 2 Share this post Link to post Share on other sites
drscooby 0 #14 Posted September 25, 2012 I work for and aircraft manuf... stay away from mpd. try some vinegar Share this post Link to post Share on other sites
drscooby 0 #15 Posted April 3, 2014 I work for and aircraft manufacturer ... stay away from MPK. try soaking it in some vinegar. and soak it for a few days. Acetone evaporates fast, if I remember right there is acetone in seafoam and they say to be careful around plastic parts Share this post Link to post Share on other sites
rwilson 128 #16 Posted April 3, 2014 Never had a problem with an E-Tank Share this post Link to post Share on other sites
Coadster32 793 #17 Posted April 4, 2014 Never had a problem with an E-Tank X2. Share this post Link to post Share on other sites
Joefrommi65 26 #18 Posted April 4, 2014 (edited) There is a penetrating lubricant called Kroil it is an industrial strength lube and can only be bought online there is none in stores. Seen it on the TV show Stacy Davids gears and the guys at work swear by it (factory mechanics) just soak it down wait a couple days and then try should come out easy. I haven't purchased yet but plan on it real soon. I use kroil at work all the time and it works well, and I found it at a auto zone and use it at home also. It smells pretty bad but I have never had a problem with plastic breaking down when using it.We use the aerosol can at work but I bought the gallon can and use it in a spray bottle. Edited April 4, 2014 by Joefrommi65 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,765 #19 Posted April 4, 2014 If you have some Seafoam fuel treatment try that. They package it in a spray can and call it Deep Creep. Garry Share this post Link to post Share on other sites
rannug 0 #20 Posted January 18, 2015 Kroil is the only one around my shop. If I remember correctly, I had to have it sent to my "gun shop". Really is a good product. Share this post Link to post Share on other sites
