garybllrdr 0 #1 Posted July 21, 2008 i have a c-125 with a manual lift arm just purchased a snowblower for this tractor is there any way to make the lift hydraulic or use a 12 volt ELECTRIC LINEAR ACTUATOR? or has anyone done something like this any help would be appreciated , Thanks Share this post Link to post Share on other sites
rustyoldjunk 127 #2 Posted July 21, 2008 i dont know if wheel horse ever used a helper spring or counter weight,such as JD or simplicity did,but maybe that could be an option too? Share this post Link to post Share on other sites
BairleaFarm 344 #3 Posted July 22, 2008 Yes you can use actuators and maybe hydrolic lift if your tranny is a hydrostaic drive. You can also add hydrolics is you wanted to but your looking at alit of work. Share this post Link to post Share on other sites
kpinnc 16,525 #4 Posted July 22, 2008 Yes you can use actuators and maybe hydrolic lift if your tranny is a hydrostaic drive. I think the 125s used an Eaton tranny, and unless it already has hydraulics (meaning it's an 1100 series pump), you won't be able to add them from there. The "non-hydraulic lift" models used a 700 series Eaton, which did not have the external charge pump for hydraulics... BUT, you can add hydraulics with an external pump (power steering pumps work well), or as you said, use an electric actuator. Good luck! Kevin Share this post Link to post Share on other sites
Rod(NASNUT) 1 #5 Posted July 22, 2008 I saw this on E-Bay Item number: 320275193148 Share this post Link to post Share on other sites
bluetuna08 0 #6 Posted July 22, 2008 unless you have a charging system on your horse I think you would need to run a deep cycle or a marine battery 12volt battery for any winch or linear actuator. even with a deep cycle battery you would eventually run out of juice. Share this post Link to post Share on other sites
garybllrdr 0 #7 Posted July 22, 2008 my hiorse has lights head and tail i think i saw something about a charging system on this am i correct? also if can mount a steering pump why not do the same with an alternator for charging if not? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #8 Posted July 23, 2008 Your C-125 has a 15 amp alternator built in to the Kohler engine. WH offered an electric lift that used a linear actuator, so as long as you don't overkill on your electrical add-ons, you shouldn't have any problems. B) Share this post Link to post Share on other sites
BPjunk 184 #9 Posted July 23, 2008 Wheel Horse does offer a "helper spring" for using a snowblower, for you guys that remember the old "hood springs" on car hoods this what the helper spring looks like. Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
HorseFixer 2,014 #10 Posted July 23, 2008 for you guys that remember the old "hood springs" on car hoods this what the helper spring looks like. Wild Bill in Richmond, Va. Yeah I remember Bill! Even tho I hate to admit it! Duke 1 Share this post Link to post Share on other sites
linen beige 16 #11 Posted July 23, 2008 Yeah I remember Bill! Even tho I hate to admit it! Duke I see two every time I check the EARL on my truck. :whistle: 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #12 Posted July 23, 2008 Wheel Horse does offer a "helper spring" for using a snowblower....... But the lift "flag" has to have the extra tab with the hole to be able to use the spring. (or a tab can be welded to a plain flag) Share this post Link to post Share on other sites
Raider 2 #13 Posted July 25, 2008 Anyone have a picture of that helper spring arrangement? I'd like to see if that would work on my Raider/snowblower. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #14 Posted July 25, 2008 Here's the IPL drawing: I never had one with the assist spring, but I'm pretty sure the front of the spring hooks to the footrest cross bar. Share this post Link to post Share on other sites
