glgrumpy 35 #1 Posted September 10, 2012 Tractors apart w/out engine. Would like to spin the shaft for the rear-end pump. It is big 3/4" shaft. Want to spin with a drill maybe, but only go to 1/2". Not sure drill would be fast enough. Maybe use 3/8" drill? but then not fitting even worse. How to connect? Say an old pulley center, then weld on 3/8" bolt? I don't have any old pulleys now. Can't think of anything in hardware store to slip and tighten on shaft and still allow welding on. Any ideas? I tried a rubber sanding drum in drill and rested on pulley. Doesn't go very fast and nothing seemed to move at all. Not sure if just the speed or ?? I tried the hydraulic lift at same time, and no movement. Electric motor and belt? I don't have motor now either. Messing with a mount is pain, maybe where motor Was on tractor? Lookin' more like I'll be assembling whole tractor and putting in engine before I can test it. Need an idea to try to run it before that if possible. Share this post Link to post Share on other sites
Foozerush 40 #2 Posted September 10, 2012 Hey Grumpy... go to Transmissions and transaxle section and read a thread by squont on how to flush hydro/lift unit. He just used another WH and ran a belt from running tractor pto to hydro pully to turn it. pics show how he did it. I dont know how to post threads to other threads in the forum. Not computer smart enough!! but hopes this helps.... Fooze Share this post Link to post Share on other sites
Duff 206 #3 Posted September 10, 2012 Here's Squonk's thread: Duff :thumbs: Share this post Link to post Share on other sites
Foozerush 40 #4 Posted September 10, 2012 Thanks Duff!! Share this post Link to post Share on other sites
glgrumpy 35 #5 Posted September 11, 2012 It Worked!!! I used my charger 12 to run the 14 axle, using the orig 14 drive belt even.....and it works! I'm so glad! Was really afraid I had gotten a lemon. The hydraulics work too. NOW, I can take the axle back out of frame and clean up and paint and re-install! Been a good day, thank you very much for that great idea! Share this post Link to post Share on other sites
