SMITTY
Charger 9 With tecumseh 10
SMITTY
Anyone know place to get Parts for model HM100 1150095b Checked Jacks no match to model #
KATO
Did you mean hh100 115095b??? If so That spec # is pre 1970 you won't find it listed . My hh100 is 115145b also not listed anywhere, but depending on what you need
ALOT of the parts from later models will fit. I used spec# 115145c (second half of 1970 and all of 1971). The rod, piston, rings, gaskets
bearings, valves are all the same . Camshaft will be different because you likely have engine mounted fuel pump, but that can be interchanged and cover plate made for block.
Cyl head will be different because of mounting tabs for the tins ,but could be made to work.
perry
what are you looking for ?. I have some tucky engines and parts .
SMITTY
Right now looking for Magneto or coil whichever you call them. No it is HM 100
SMITTY
Hi Perry
I need a solid state module 610748. I live in Waterford would like to meet you sometime.
KATO
There are 2 different styles of this module. you can search e-bay for Tecumseh HH100 and you will see a couple. Or this link to Weldmart who makes a replacement for the 610748 module.
http://www.weldmart.com/techtalk/?tag=tecumseh-610748.
KEN
SMITTY
Hi Ken
They don't have them anymore. Also it was a converstion to an exterior coil anyways and they are available elswhere. Thanks for your help
Smitty
