mrc
tiller questions
mrc
hi guys, i've heard there is a tiller lift assist spring??? same as the snowblower lift assist spring??? part number??? i'm also told it hooks to the hole in the angle iron for the rear axle mount but, where does it hook on the tiller??? thank you for any help. mike in mass.
Forest Road
Its probably a bad idea. You don't want the tiller bouncing while in use. Which is exactly what that spring cause.
Kelly
yes same spring I don't know the part no. off hand, the axle bracket top plate on the left side you substitute the angle iron piece and have the hole to the rear, on the tiller there is a bracket with a eye bolt in it that you hook the other end of the spring to, not all tillers have the bracket, but I have a extra if you need one.
can whlvr
i use the assist spring for both,and it does not make the tiller bounce at all,just makes it easier to lift on manual lifts
