Houdini#48 0 #1 Posted September 5, 2012 My belt keeps jumping off the deck and PTO. Upon closer inspection I noticed I had a carriage bolt fall out from my 37" side discharge deck. Thought that was the problem. Put a temporary replacement in until the new one arrives, put on a new Wheel Horse brand belt, read the belt tension adjustment guidelines and the darn thing still jumps off upon PTO engagement. What in tarnation am I doing wrong? Is it mower level adjustment, traction lift bar-trunnion & lift rod adjustment or transport level stop adjustment. Can there be any more deck adjustments? I'm just wanting to mow my lawn. Share this post Link to post Share on other sites
GlenPettit 1,717 #2 Posted September 5, 2012 You've done everything exactly right. Somewhere there is a little something out-of-whack. -- There should be about 1/2" deflection in the belt for the correct tension, (in the front "mule" to deck section of the belt). -- Sounds crazy; but are all four of your tires all inflated to the same 10 psi. -- Touch all bolts, pulleys, blades to see is everything is snug/tight, with power off. -- Compare the Owners Manual Photos with your deck, the trunnion & life rod positions. -- Does this happen right away; just setting there on the drive, on level light grass/ground, or just in tall thick grass? We're all here to help, And sometimes it seems to just take a little Magic! (Re: Your Screen Name) Share this post Link to post Share on other sites
cheesegrader 433 #3 Posted September 7, 2012 Check your motor mounts. Mounts from motor to plate, and plate to frame. I had the same problem when I got mine a few years ago, and I did all the things you tried. I finally realized that the motor was twisting on it's mounts on PTO engagement just enough to throw the belt if I hit a bump. Found the loose bolts between the plate and frame, tightened them (with much cursing and a little loss of skin off my knuckles) and the problem stopped. Share this post Link to post Share on other sites
Sparky-(Admin) 23,524 #4 Posted September 7, 2012 Any chance we could get a picture of your setup? Mike........... Share this post Link to post Share on other sites
